Ok guys, as promised here's the RSX I did a couple years ago for my good buddy from High school.
The goal here: Build a decent/moderate setup, that looked nice but could be 100%HIDDEN. This guy's dad, who bought him the car, would literally murder him if he knew he put a system in it and how much he spent on it.Thus it had to be "STEALTH MODE".
To this day, after 2 1/2 yrs of his pops borrowing this car to go golfing, he still has no clue it's there. MIND you, the deck face was never there so he cant listen to it but it's pretty well hidden is all i'm sayin, as were my instructions.
He worked at Best Buy @ the time and supplied all parts via his employee accomodation. Here's what I had to work with:
Deck: Clarion VRX925VD indash DVD player
Front mids: Fosgate FNP 6 1/2" Component set
Rear Mids: Fosgate FNP 6 1/2" Component set (had to get a lil creative to mount em)
Subs: 2-Fosgate HE2 12's (D2's)
Sub Amp: Fosgate 501X
Mid Amp: Fosgate 401S 4 channel
The exterior pix of the car are just some that I found online cuz I didnt take any pix of the outside of the car while I had it (I should start). But it WAS Black, a type-S, had the big GROSS (IMO) Wing...
Posted Image
-and stock everything else.
Here she goes:
Posted Image
Posted Image
Front shot of one w/ no wing (non type S)
Posted Image
Posted Image
Gauges ooooh...
Posted Image
Posted Image
Posted Image
Posted Image
Here's his Clarion VRX925VD indash he had already when he brought it to me...
Posted Image
Later switched to an Avic D1 and added the center channel for D5.1 surround.
Fosgate tweeters in the stock dash location
Posted Image
I had to make 3/4" mounting rings for the front mid-woofers so the magnets would clear the window in the door...
Posted Image
And they worked out
Posted Image
The rears were a lil tricky just cuz there was no place for the tweeter, so it got surface mounted BEHIND the interior panel as you see here...
Posted Image
I had to shave quite a bit off of the backside of the panel to open it up for the sound to get out but it worked perfectly and sounded really nice to my surprise (RF ftw i guess)
Posted Image
I made sure to take this pic w/ the screwdriver pointing out the tweeter hiding behind the panel cuz otherwise you'de never know it was a comp set unless you pulled the whole panel which runs 3/4 the length of the car.stock look FTW.
Posted Image
OK so here's the before of the trunk.
Posted Image
So I tore that down to nekkid and started by maskingwith DUCT tape & foiling off the trunk area
Posted Image
Posted Image
Layed a layer or 2 of resin/fiberglass/more resin
Posted Image
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box02.jpg
Pulled it out for some trimming
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box03.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box06.jpg
The trunk/tire well after I pulled the tub
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box04.jpg
I dropped it back in and realized I had needed the side parts to be ON TOP of the side panels not UNDER damnit!
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box92-1.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box07.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box08.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box8-1.jpg
So here we go re-glassin it ON TOP this time (re-mask/foil)
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box09.jpg
Then when I pulled it the 2md time I had this sexy bish
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box9-1.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box2-2.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box1-2.jpg
Ok so once that was all straightened out....
I made this frame/insert that I could mount the top boards to-
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box3-1.jpg
And I shit you not, 5 minutes after this pic was taken, I punched thru a thin spot in the fiberglass/bondo i was jabbing with 1/2" chisel and CUT A 2" GASH IN MY LEFT PALM!
******HOLY-I'M BOUT TO BLACK OUT F*CKING HELL!!!!********
That hurt.
I'd been staying up to work on this beezy trying to finish it within the 7 day deadline, and skipping meals, so when I lost that much blood I started gettin all tunnel vision
and had to take a break. In some of the next shots you can see the "bandage" around my left hand as i'm wiring it up...The show must go on yo.
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/wiring1.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box93-1.jpg
It was a rush wire job as it was deadline time and I was 2 days from being done on it but in the end I think it came out ok.
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box4-1.jpg
I threw together a lil cover piece for the middle to hide the wires
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0614.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box6-1.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/box5-1.jpg
He took his floor carpet to a shop and had em sew it up pretty nice. I put some 1/8" plexi over the amps just for a lil protection and they didnt get warm at all under it
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0608.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0610.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0611.jpg
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0613.jpg
Subs sit 3/4" under floor level for clearence.
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0615.jpg
Bass knob up front
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0620.jpg
All done.
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/Done.jpg
Cover back in place so pops doesn't see whats underneath
http://i9.photobucket.com/albums/a68/CasperDaBoi/Projects/IMGP0607.jpg
I think thats it folks.
Lemme know what ya think.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
  • Replies 24
  • Created
  • Last Reply
ouch on that gash
amazing work champ, very well done...nuf' said
I see Booty
2007 Toyota Camry
19" VMR Rims
H&R Lowering Springs.
Magnaflow Exhaust System
K&N Air Intake
6k HID Projectors & Fogs w/ Black housed headlights.
Optima Yellow Top - Front. Kinetik HC 600 - Trunk
Kenwood KVT-617
Rockford Fosgate 3sixty.2
Rockford Fosgate T2001-BD - Sub Amp
Alpine MRV F-345 - Front stage
Front Stage - A pillars - Dayton Audio 4" mids w/ Vifa Tweeters
Front Doors - Vifa - 6.5" midbass 1" Vifa Tweeters
Subwoofers - 2x 12" Image Dynamics IDMAX - 2.91 cuft ported enclosure tuned at 25hz
Thanks guys.
I forgot to mention-FREE LABOR on this one.
**Double ouch**
Thnx Pokey.
Yea, the fact that I didn't have to raise the floor level at all + that lil rubber cover goes a long way in concealing what's underneath.
I liked how he still had essentially his WHOLE trunk left, and could roll around bumpin it even w/ stuff in the trunk no worries. I was pleased with the outcome and even got to enjoy ridin around in it a bit down in San Louis Obispo where he went to college (Cal Poly)
Some good times. Worth the pain for sure.
Thnx ffry.
Mission accomplished.
nice install, i miss my HE2s
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   1 Member, 0 Anonymous, 269 Guests (See full list)
