I am going to go through and drop the SAZ-1000D, SAE-1200D, SAZ-1500D, SAZ-2000D, SAZ-3000D, and SAZ-3500D in the Jeep and do a power clamp test so we have a rough and UNIFORM comparison between the amps in the same setup.
Test Frequency - 50 Hz
Test Load - 4x SA-12s all in parallel for 0.4375 DCR (1/2 nominal)
Test Electrical - 6x Stinger SPV-70 + 225-Amp Alternator (vehicle only at idle)
Amp gain set to 1/2 - Head Unit Sub Control 10/10 - Head Unit Volume 50/50
Setting gain to half on each amp is, of course, not an exact match... but for the sake of roughly comparing the amps I think it serves the purpose.
Posted Image
SAZ-1000D:
Posted Image
POWER : 1040 Watts
AMP VOLTAGE (measured) : 37.2 V
AMP CURRENT (calculated) : 27.95 A
ACTUAL IMPEDANCE (calculated) : 1.33 ohms
SUPPLY VOLTAGE : 13.15 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2498.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2499.MOV
* Voltage Measurement
SAE-1200D:
Posted Image
POWER : 1770 Watts
AMP VOLTAGE (measured) : DID NOT MEASURE
AMP CURRENT (calculated) : DID NOT MEASURE
ACTUAL IMPEDANCE (calculated) : DID NOT MEASURE
SUPPLY VOLTAGE : 12.65 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2513.MOV
* Power Clamp
DID NOT MEASURE
** FUSES BLEW - DID NOT CONTINUE TO MEASURE VOLTAGE
SAZ-1500D:
Posted Image
POWER : 1970 Watts
AMP VOLTAGE (measured) : 49.25 V
AMP CURRENT (calculated) : 40 A
ACTUAL IMPEDANCE (calculated) : 1.23 ohms
SUPPLY VOLTAGE : 12.85 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2493.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2494.MOV
SAZ-2000D:
Posted Image
POWER : 2440 Watts
AMP VOLTAGE (measured) : 56.18 V
AMP CURRENT (calculated) : 43.43 A
ACTUAL IMPEDANCE (calculated) : 1.29 ohms
SUPPLY VOLTAGE : 12.5 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2503.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2504.MOV
SAZ-3000D:
Posted Image
POWER : 3280 Watts
AMP VOLTAGE (measured) : 61.28 V
AMP CURRENT (calculated) : 53.52 A
ACTUAL IMPEDANCE (calculated) : 1.14 ohms
SUPPLY VOLTAGE : 12.1 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2506.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2507.MOV
SAZ-3500D:
Posted Image
POWER : 3660 Watts
AMP VOLTAGE (measured) : 65.84 V
AMP CURRENT (calculated) : 55.58 A
ACTUAL IMPEDANCE (calculated) : 1.18 ohms
SUPPLY VOLTAGE : 11.9 V
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2510.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2511.MOV
SAZ-4500D:
Posted Image
* SAZ-4500D in prototype case
POWER : 4870 Watts
AMP VOLTAGE (measured) : 76.0 V
AMP CURRENT (calculated) : 64.08 A
SUPPLY VOLTAGE : 12.25 V ***
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2529.MOV
* Power Clamp
http://www.sundownaudio.com/misc/_AMP_POWE...0D/CIMG2530.MOV
*** - Measured different day from other amps (8-4-09), batteries had full charge so sustained less voltage drop.
These are not necessarily definitive tests on the amps.
All applications are different and I could have probably squeezed more out of an amp here or there... but for the sake of this test I just set the gain knobs to physically 1/2 way up.
Just a rough guide to show what the amps can do!
I may go back one day and do an SPL comparison as well -- as we have seen up to 1 dB increase from the 3000D to the 3500D even though the power test doesn't seem to indicate as much. With the SPL portion I would sit down and tweak knobs until I got maximum SPL per amp.
I tested amps from smallest to largest (for the most part except 1200D was tested last) -- so the batteries did not have a complete full charge by the time I got to the big amps, just a few minutes of alternator charge time... that just means the bigger amps will produce more than posted if I had a complete charge. This was mentioned in my initial post so I thought I would post it here as well.
Edited by sundownz
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
NICE! that box looks sexy too!!!
(thanks bro)
Follow my Tweet (Twitter)
I must say that little 1200 is a beast.. still have not played with my 1500, looks promising
DC.jpgDC POWER
very nice results. any testing on the 4500d :P
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
