Very nice man great gains on the HP! And the car looks great!
Thanks, Its a HUGE difference now. its Quick, with the higher compression bottom end I don't need much boost to make this think come to life.
lower tuning is just hard. I was surprised how loud 145 sounds at 35hz, and how quiet 145 sounds at 50hz.
-= 2005 Tahoe LT =-Head unit: Pioneer AVH-X5500BHSSource: iPad Mini in dash
Subs: 2 T1 12's
Sub Amp: T1500-1bdCPWire: Rockford Fosgate 1/0 awgSignal Cable: MonsterFronts:Stock Bose for now:)Rears: Stock Bose for now:)MIds/High amp: Stock Bose for now:)
2005 Tahoe Build Log: http://www.stevemeadedesigns.com/board/topic/172529-2005-tahoe-my-17th-vehicle/
2001 Monte Build Log: http://www.stevemeadedesigns.com/board/topic/160030-2001-monte-carlo-my-16th-car-lol/page-2#entry25309381997 Tahoe Build Log: http://www.stevemead...oe-6-15-rf-15s/2001 Impala Build Log: http://www.stevemead...katzkin-inside/SMDSig3-26-12.jpg
::http://www.youtube.com/watch?v=GLczrOW9vs0
here you go DELETE the "::"
Subs: 2 T1 12's
This is what the engine bay looks like now with the 3.5" pulley and the ZZP Headers. This car really moves now :)
Subs: 2 T1 12's
I might have missed it, but are you using the GTP computer in this car now? My cousin and I really wanted to do this swap into his Impala a little while back.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
It doesn't matter which PCM you use, YOU WILL ABSOLUTELY NEED A CUSTOM TUNE. The L36 block(N/A) 3.8 is 9.4:1 and the L67 (S/C) block is 8.5:1. You also Cant just bolt on pulleys with out doing a lot of supporting mods first. The higher compression block DOES NOT need as small of a pulley. A top swapped car will yield ~10% more power than a factory S/C'd car at the same mod level. My car will absolutely destroy a GTP that has a 3.5" pulley ;) ZZP can send you a PCM that is all tuned for your mods and the top swap but I wanted a dyno tune to ensure I got what I paid for. 252WHp and 321WTQ, I'd say so :yahoo: My car made ~160 at the wheels stock a GTP stock makes ~190WHP.
Subs: 2 T1 12's
The BEST mod you can do for any W body car (Impala, Monte, GP, Bonne, Regal, etc) is the AeroForce scan gauge, it is one of the few that can detect KR (Knock Retard). KR is the most important thing to know in my car. You can even set it up to flash the lights if you exceed the parameters that you set. check into it. They are about 240.00 but ONE gauge does EVERYTHING Literally!
Subs: 2 T1 12's
Very nice. That makes the most sense actually lol. Definitely a badass car!
My feedback thread
Thanks, should run mid 13's in the 1/4 and is capable of 146+ DB's :):drinks: I going to be modding this thing as much as possible with out installing a cam. I want to keep the drive ability and MPG. I will be using 1.9 Rockers to add another 20+ HP than dropping another pulley size and adding 1 or 2 degrees of timing to achieve close to 300WHP. Im sure ill nuke mt trans soon after so a ZZP trans is on the list too :):drinks:
Subs: 2 T1 12's
