Welcome to SMD Forum
cheapest way to run a car amp on wall power?
18 replies to this topic
#1
412 CVX
412 CVX
    165db
  • Deleted
  • PipPipPipPipPipPipPipPipPipPipPip
  • 4,247 posts
  • Gender:Male
  • Interests:I Ruin Boxes.
Garage View Garage
i've got a couple of jl 12's that used to be in my car before i decided it was time to upgrade.
wanted to know the most cost effective way to use the car subs for my room. i'm likely going to sell the system soon, so i'm not really looking to spend very much money.
and i know car subs are meant for cars and not homes, but idrc. i just wanted to experiment a little bit and wondered the best way to do this.
thanks
Just say no to Ground Pounder Customs.
My temp system build log
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
#2
ALPINE408
ALPINE408
    175db
  • SMD Gold Member
  • 8,081 posts
  • Gender:Male
i allways used a car batt charger on like 10 amps. for a test beanch. if you have a lil batt with the charger is even better
#3
Kranny
Kranny
    The Kranny rule
  • Members
  • 18,988 posts
  • Gender:Male
you can either use a car battery charger and attach it to a battery as Bassick statedm or you can buy a computer power supply (preferably over 1000w) and attach all the yellow 12+v wires to the amplifiers 12v+ and the adjacent black wires for ground, to the amplifiers ground terminal respectively. then find the large 20 or 24 pin connector and find the green wire and the adjacent black wire and find a way to attach them together, either a paper clip (not really safe lol) or cut them off and solder them together etc. this will simulate the computer turning on and it will kick on the PSU. then take a short piece of wire and bridge the 12v+ and remote terminals on the amplifier.
#4
dolarbilz
dolarbilz
    n()()b
  • Members
  • 3,568 posts
  • Gender:Male
  • Interests:Beer,stereos,
Go to parts express and look at plate amplifiers. No need to try to wire things.use battery or car charger.just me
#5
Reallunacy
Reallunacy
    130db
  • Members
  • 371 posts
  • Gender:Male
If I were to go that I would use a computer PSU. However, I have to agree with dolarbilz on just getting an amp that is designed to work off of 110v.
#6
dolarbilz
dolarbilz
    n()()b
  • Members
  • 3,568 posts
  • Gender:Male
Which Jl u have..u wouldn't need goobs of power to make these subs work.
#7
kickass audio
kickass audio
    150db
  • Members
  • 1,956 posts
  • Gender:Male
  • Interests:cars, women, computers, electronics, anything that is electrical and you can manipulate in numerous ways.
Garage View Garage
Just my opinion on this. I have a 750w computer power supply that i bought a long time ago for a damn good price of $40 when circuit city was going under. It works great for mine but it by no means has the amperage behind it to keep my amp powered on for my sub. I have it running my old fusion reactor ream-900 amplifier and it is a pretty decent amp from what i use it for but i have to have the resistance up higher than hell or else it draws a lot of current and my psu i have goes into protect mode due to it being overloaded. So as a precaution dont expect to crank out the same power you can in your vehicle by using a power supply. it just wont happen.
And Kranny im not trying to say you were wrong at all but you dont need to take all the positive and grounds to the amp. I would just say that if possible make the runs as short as possible because as we all know the 12/16 gauge wire that the power supplies come with is not enough for running a car amp. I had mine on the stock 3 foot run (yea thats right a 3 foot run of the stock power supply cable!!!) and the end of the wire closest to the amp got pretty warm from it being loaded up with a ton of power. The PSU will get you going but if you expect to wire your speakers up in a very low impedance or crank the power dont expect it to stay on. Either you will fry your power supply or you will make the power supply go into protect mode like mine does and you have to reset it by pulling the plug from the wall for 5 minutes.
2004 GMC Envoy
1 XS power S3400 batt under the hood and 4 XS Power D3100's battery installed in the rear by the amps
0 gauge power wire from front to back
Alpine iva-w205 touchscreen dvd/cd/mp3/ipod/am/fm/gps headunit
Sundown Audio SAX-200.4 amp for my mids and highs
8 gauge speaker wire from amp to woofer
270 amp Mechman Alt
Rockford Fosgate T1652-s component speakers
Rockford Fosgate 3Sixty.2 sound processor
Rca's from Rockford Fosgate and Monster Cable
14 gauge speaker wire for the mids and highs
1 18" Ascendant Audio SMD Dual 1 ohm with custom Black & Blue carbon fiber and hand signed dustcap
Box: 5.66 cubic feet net volume box tuned to 30.13Hz with 1.5" wide wooden dowels and 1.5" thick baffle
1 DC Audio 5.0k amp wired to .5 ohms nominal with an imp rise of 1.35 ohms for the single AA SMD 18"
Future Vision 8000k 50w bi-xenon projector HID's with 4300k 35w fog lights
Link to my build: [font="Arial, sans-serif;"]Buildupdates/progress[/font]
#8
412 CVX
412 CVX
    165db
  • Deleted
  • 4,247 posts
  • Gender:Male
Garage View Garage
i'm actually only using a 500 watt amp. don't need a tonna power. i just wanna see if it will work, and play around with it a bit.
i've got the W0v2's. spent waaay too much for the system.
anyways as long as i can get like 100-200 watts going, i'll be happy.
Edited by 412 CVX, 19 March 2011 - 03:13 PM.
More box builds
#9
White Lightning
White Lightning
    Sound Quality
  • SMD Gold Member
  • 5,999 posts
  • Gender:Male
  • Interests:GMT400
Garage View Garage
Simple ... Astron power supply ...
Randal Johnson
Team Linear Power
Tractor for sale.
Runs good. Missing the seat and steering wheel.
Ideal for the man that has lost his ass and has nowhere to turn.
Make Offer.
#10
kickass audio
kickass audio
    150db
  • Members
  • 1,956 posts
  • Gender:Male
Garage View Garage
yea my amp is only like 250w rms at 2 ohms and when i wire to 2 ohms i can get it to sound good but when i start to raise the volume it draws so much current it shuts off the power supply from it being overloaded. So you can do it but just be warned that you will more than likely overload the powersupply and make it go into protect mode or melt it.
2004 GMC Envoy
270 amp Mechman Alt
#11
White Lightning
White Lightning
    Sound Quality
  • SMD Gold Member
  • 5,999 posts
  • Gender:Male
  • Interests:GMT400
Garage View Garage
I agree with dollarbilz ... Get a plate amp and not worry with the confusion ...
Randal Johnson
Team Linear Power
Tractor for sale.
Make Offer.
#12
Ascending Mayhem
Ascending Mayhem
    120db
  • Members
  • 39 posts
  • Gender:Male
  • Interests:160db @ 20hz
MY HOMIE USES A WALL CHARGER THAT IS RATED AT 12 V AND HE POWERS A 300w amp BRIDGED on a 12" Rockford woofer. He said hes never had a problem. ? NOT SAFE? I DONT KNOW! AT YOUR OWN RISK OF COURSE. AND IM ONLY SAYING THAT CAUSE IM AN AUDIO GUY AND THIS IS AN AUDIO FORUM.
2003 Dodge Intrepid 3.4L v6 Stock Alternator 12.5 V all day.
DREAM SYSTEM IN PROGRESS> STILL JUST A PLAN....
(2) Custom Ascendant Audio Mayhem 15's 6th order walled
(1) (4)JL Audio 1000/1 V2
(4) JL Audio 500.4
(5) XS Power D3100 (1) XS Power D1200
(1) Mechman Alternator 400+ AMPs
(8) Tang Band W8-1772 8" Neo Drivers
(8) Tang Band 25-1166SJ 1" Neodymium Tweeters(2) in each pillar
(4) Dayton PS180 6.5" Neo Full Range Drivers in Rear Shelf
(4) Eminence Delta Pro-8A 8" Midrange
Reply to this topic
