Torres box calculator
eric78702
read this
Box Frequency Tuning Calculator - FAQ/Tip Guide
1 - First and foremost, the RE calculator is *not* spot on, and is limited in design, so no, it will not match this calculator.
2 - When doing an oddly shaped box such as a fiberglass box, or you know the volume of a certain box you have in mind
that you want to build, put the net volume in the 'Desired Net Volume' box. This will bypass all dimensions entered
preventing you from having to guess dimensions to get a certain net volume and will allow you to tinker with different
port sizes and tuning. So if you know you want a box with 4 cubic feet of net volume, enter '4' into that box and it
will allow you to adjust tuning accordingly to that specific volume. Keep in mind that any displacement nor port volume
is NOT subtracted from this total.
3 - The 'Desired Gross Volume' box acts much like the Desired Net Volume box, except all displacements are taken into
effect.
4 - If the number of aero ports is greater than 0, then that automatically gets taken into effect and the calculator ignores
the dimensions for slot ports.
5 - The '# of Common Port Walls' box refers to how many sides of the box are going to act as sides of the port.
6 - Port length uses the box wall or baffle(s) as part of the port length. So a port that is 10" long with one baffle using .75"
wood will only need to be 9.25" long as the box wall or baffle(s) will account for the other .75". If using two baffles,
then it would be 8.5" long as the baffle will account for 1.5" of port length.
7 - Port walls are defaulted with a .75" thickness.
8 - Regular square/rectangle boxes do not need any numbers entered into the 'Height 2' or 'Depth 2' boxes.
9 - Pressing 'Enter' will prompt the program to print.
10 - Slot port area range is based on 12-16 square inches of port per cubic foot, while aero ports are based on 9-13 square
inches per cubic foot.
10 - On the cut sheets of boxes with different depths and heights, you'll notice 'H1' or 'D2' next to the measurements.
These represent which dimension is which. Here are two pictures to illustrate:
Box with one height, but two different depths: http://img59.imageshack.us/img59/8449/angledcutsheet1.png
Box with two heights and two different depths: http://img163.imageshack.us/img163/607/angledcutsheet2.png
If they do not go in the proper order, the sheet will not come out properly.
--Here is the formula the calculator uses (the same on displayed in the program itself):
http://img713.imageshack.us/img713/2590/tuningformula.jpg
--The following are links that illustrate how each ported box is taken into effect in the calculator (sub and port position can be upwards with the same effect):
1 - Port with 0 common walls: independentport.jpg
2 - Slot port with 1 common wall: bottomportbox.jpg
3 - Slot port with 2 common walls: middleportbox.jpg
4 - Slot port with 3 common walls: slotportbox.jpg
--The images were made with Google Sketchup. Free to use: http://sketchup.google.com/
R.I.P!
(Nov-29-2009)
92 explorer
current build
make your own visual do you need everything handed to you or what>?
yeah it makes things a lot easier for me haha:)
With this response don't expect any help. Get off your ass, use your own brain, and fours it out. Or cough up the cash or someone to hold your hand and design one
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
I think I would want someone to hold my hand and design one for me because I know it's right and not wrong. You feel me?
Then pay someone for a design
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Na I'll just asking someone to help me. Someone will be willing to.
lol
Did Joo pay copywrite fee's for your avatar pic???
¿ǝɯɐƃ ǝɥʇ
lol
no seriously read my fucking post up top it tells you the how two's of torres calc
play around with it and come back to us (in this thread) with what you've come up with and we'll help you from there but if your going to be a little stubborn child not wanting to learn how to learn anything because something as stupid as i cant picture it
ps.. learn how to use googlesketchup
R.I.P!
(Nov-29-2009)
92 explorer
current build
lol
I came up with something but I can't post it >|
