XS Power
XS Power Battery Proper Charging Info
•It is very important that proper charging techniques be used when charging XS Power batteries. XS Power batteries are designed for use with the XS Power battery chargers with a MAXIMUM output voltage of 2.4 volts per cell (14.4v for 12v batteries and 19.2v for 16v batteries). AT NO TIME during charging should the battery be subjected to more than 2.4 volts per cell. Voltages above this will cause the battery to “gas” and once the oxygen is vented it cannot be restored.
•Under-charging XS Power batteries is equally damaging to the life of the battery. Take special care to ensure
that the battery is properly charged before the initial use by verifying the open circuit voltage is above 2.1
volts per cell (12.6 for 12v batteries and 16.8 for 16v batteries). Improper charging can cause damage that
is permanent and will VOID THE WARRANTY. If you are unsure if your charger is AGM compatible, please
contact the XS Power Batteries Tech Support Department at 888-497-7693, or email us at [email protected] for more details.
  • Like (+1 Rep) 4
  • 6 months later...
Im about to get a used xs d3400 it sits at 13.0 and that is fine im assuming.
<p>Pioneer AVIC 6000 NEX, JBL 660c Components - FI SP415- Arc audio xdi2000.1- Xs Power- 0 gauge, Big 3 Upgrade Dc Power xp270
I just bought a cheap lil agm charger "Schumacher " xcs15 will this suffice for charging my d3100 nd my d925's?
2x dcaudio lvl4xl 15's
1x dc power 270xp alt
2x rockford 2500 1bd
2x big3 2x front to back 0.gage jl
1x optima yellow top under the hood
1x xs power d3100
2x xs power 925
148.6 db sealed to music 149.5 db sealed 42hz term lab
Thanks ill check it
1x xs power d3100
2x xs power 925
  • 3 weeks later...
I have a d3400 battery up front and plan on installing a d3100 in the trunk, BiG 3, 2 runs 0 g. POS. (250 amp fuses) & 2 runs 0g. NEG. to the D3100 parallel.
amps: (1) Digital Designs S4a, (1) Digital Designs SS2a (1) Digital Designs SS3a, (1) SKAR Audio 4500.1D (2) runs 0g. POS. & NEG.
MECHMAN 270a alternator
will this setup be enough or do you have a recommendation?
In my opinion, you really need more under the hood - 2nd alt. You can keep adding batteries but you dont have a sufficient source of amperage. Batteries only store power, they don;t produce it. You can add batts and monitor voltage and adjust your sound to let the batts charge up again as an alternative.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
  • Who's Online   0 Members, 0 Anonymous, 235 Guests (See full list)
