XS Power
XS Power Battery Proper Charging Info
No room for a 2nd alt. in a Pontiac GP will be just adding batteries and monitor voltage
I had the same problem in my 2004 audi s4. Had no room with the v8. Just send your alternator out and have it built up to spec.
Fantom
The only real way to get a second alt on the V8 is to give up your air con pump ;)
Audi A4 Avant
Dual 210a Alts - Spl Dynamics D6 - 2 x Fi SP4 15
Boot Install
  • 2 months later...
Sox if I get a D2700 and the voltage out of the box is between 12.6 at 12.8, I won't need to charge it?
2002 Dodge Dakota 4.7 club cab - Sold 2004 Audi S4 Avant
- Fi and Crescendo - Stock Bose System
- http://www.stevemeadedesigns.com/board/topic/147725-2002-dodge-dakota-end-of-the-road/?hl=%202002%20%20dakota
136.4 Sealed @ 29hz
137.0 Drivers window open @ 26hz
my mechman alt only charges at around 13.8, and thats due it being internally regulated, nothing I can do, now that really never tops it off, but I do have the intellicharger built into my car so I just plug it in whenever im not driving, my question is, is it bad for the batteries to never be charged at 14.4? I have looked at some diode mods that allow make the alt charging voltage raise by about .8v by placing a diode inline with one of the wiresm im considering that, many times it charges at 13.4 or so too, with not much load, all having to do with the car trying to be fuel effient :(
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
If you have the charger and top them off every now and then you should be good.
I stick em on the charger everytime I am home, my alt is always adjusting voltage guessing depending on how the load is, and since car audio you have amp load always changing it jumps around a lot, wish I had a module to just set it at 14.4 :(
Pioneer 4300DVD
  • 3 weeks later...
  • 1 month later...
  • Who's Online   1 Member, 0 Anonymous, 371 Guests (See full list)
