XS Power
SE-1275A Schumacher ok for XS Power battery
I need to pick up a charger for my other batteries and I was wondering if i can kill two birds with one stone and use this with my XS battery too. It has a 2 amp setting and I believe a 12 or 10 amp setting.
Pioneer AVH-P4200DVD
Rockford Fosgate T5001 bd-cp
2 DC level 2 12's
Focal Access Components in the front
Focal Access Coax in the rear doors
Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75
XS Power D3400 under the hood
Knuconceptz Ultra Fleks Power & Ground
It's a 2/12/75 amp charger. The 75 position is for starting instead of using another car to jump the dead one.
2 DC level 2 12's
"AGM compatible (max 14.4V) and around 15amps charge rate. It would be better to charge at 10amps than 25amps though on a single battery. Its better to look for a intellicharger type that will actually go into a float mode and maintain the battery while it is being charged. This way if you had to or wanted to you could leave the battery hooked up to the charger 365 days out of the year and not have to worry about it overcharging the battery." from Nathan himself. The main thing you want to make sure is that it doesn't charge over 14.4 because this will vent the battery according to Nathan and ruin the battery.
1999 Dodge Ram 1500 Ext. Cab 5.9L Laramie SLT
FI BTL 15 (UFO Slug)
Crescendo Audio 3KWP
Alpine AVH-P4200DVD
Rockford P1692's
P1653's
60 sq. ft. SDS CLD Tiles
KnuKonceptz Kolossus 1/0
Karma SS 8 Gauge
  • Who's Online   0 Members, 0 Anonymous, 264 Guests (See full list)
