#1
Posted 27 February 2012 - 12:37 AM
#2
Posted 27 February 2012 - 12:43 AM
Just say no to Ground Pounder Customs.
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
#3
Posted 27 February 2012 - 12:52 AM
sorry for rambling on, but yes basically i need help getting my box tuned to 28-30hz, link for the hdc4 18 page is here http://www.audioque....1-A-_p_137.html incase you can find the displacement.It's late and i'm getting lost in your words, but from what i understand, V(as) is not displacement. i might reread this in the morning, but if i'm skimming it correctly now, the displacement of two HDC4 18's will not be over 1 cubic foot, i can almost guarantee that
#4
Posted 27 February 2012 - 12:58 AM
if you need help with the design, feel free to PM me anytime.
#5
Posted 27 February 2012 - 01:35 AM
I will probably message you, any other input from people is stll welcome tho, ive decided ill go with the rear facing port and subs up.honestly when you can't find it, just guesstimate. unless you're chasing tenths on the meter it really doesn't matter as long as you're close. i would estimate the displacement per sub is around .25
#6
Posted 27 February 2012 - 02:03 AM
Enclosure Specifications:
Fb = 30.006 Hz
Vb = 9.049 ft^3
External Height = 25 in
External Width = 40 in
External Depth = 25 in
Port Width = 5 1/4 in
Cut List:
* All Dimensions in Inches.
External Enclosure Parts:
2 x Top & Bottom (3 parts) = 40 x 25
Left & Right Sides = 23 1/2 x 22 3/4
Front & Back = 40 x 22 3/4
L Port Internal Assembly Parts:
Front to Back = 17 1/2 x 23 1/2
Extension = 4 x 23 1/2
Audioque recommends 5 cubic feet minimum per sub, the design above is a cube short, so you need to give up more space to have a working design, also is better to specify the minimum frequency you want to listen to (F3) than tuning itself.
For example a 28 inch depth will let you reach 5 cubes per sub.
#7
Posted 27 February 2012 - 02:07 AM
Edited by 9515ROB, 27 February 2012 - 02:09 AM.
Time to rebuild.
4 15s and alot of power
TEAM DTF
#8
Posted 27 February 2012 - 02:15 AM
Time to rebuild.
TEAM DTF
#9
Posted 27 February 2012 - 02:20 AM
Thank you for the input, as for more space i can give up more height, atleast 10" more. And from what ive read after searching the forums apparently port firing to the rear is best in my application?So ran some numbers, this a port up sub up configuration:
Fb = 30.006 Hz
Vb = 9.049 ft^3
Cut List:
#10
Posted 27 February 2012 - 02:26 AM
I never had any problem with my old aq's and playing 30hz and those were twelves? Not trying to give you a negative response, just in my case when i played low song that hit around 28-30 i still got the desired deep bass and solid rumble throughout my vehicleyour going to have some fun getting a sub that has the free air response of 40hz to play in the low 30s and high 20s daily lol
Edited by ghostismyname, 27 February 2012 - 02:29 AM.
#11
Posted 27 February 2012 - 02:33 AM
your going to have some fun getting a sub that has the free air response of 40hz to play in the low 30s and high 20s daily loli may just not have heard enough really good builds to tell the difference. But i mostly plan on playing rap/dubstep/rock i want the lower tuning mostly for show i guess. I figure ill stick with 30hz like my last box, of course i never did displacement when i made it so that probably drasticaly changend my tuning. And thank you for the clarification on what Vas actualy is.
Its your box you can do what ever you want. Your best bet to figuring out what the displacement is, is trying to find the specs for subs that are around the same size and see what its displacement is.
Time to rebuild.
TEAM DTF
#12
Posted 27 February 2012 - 02:36 AM
Yes ive already sent a email trying to contact Aq and see if they will tell me the displacement. But in the mean time i guess i could mock up some design with similar size woofers, ty
#13
Posted 27 February 2012 - 02:39 AM
Time to rebuild.
TEAM DTF
#14
Posted 27 February 2012 - 02:42 AM
#15
Posted 27 February 2012 - 08:28 AM
Fb = 30.15 Hz
Vb = 11.901 ft^3
Subwoofer Mounting = Flush Mounted
External Height = 29.25 in
External Depth = 28 in
Port Width = 4 3/4 in
Cut List:
2 x Top & Bottom (3 parts) = 40 x 28
Left & Right Sides = 26 1/2 x 27
Front & Back = 40 x 27
Front to Back = 21 3/4 x 38 1/2
Extension = 4 x 38 1/2
As noted above though the 30Hz tuning is way below Fs, probably you should look into this.
Sign In
Create Account
Back to top
