Sub "pops" when car is turned off
Take dmm and ohm out your ground wires, set meter to ohms, touch the red lead to the black lead, it should mack a signal sound,,,, then touch the red lead to one end of ground and the black to the other, you should get the same signal sound, if you do it meens you have no breakes in wire ,,,,, if you dont get it then you do ,,,,,and go a head and find a better place to ground,,,, fram if poss..................... just noticed you are running AQ750, if gain is to high it will do that too...............
  • Minivanfromhell -- Proud Member of Shut It Down Boyz & GEORGIA CAR AUDIO
Pioneer DEH-3400-UB
Vega 65 cs & 1" tweets & T3 4" coax in Front
1- Dual 300 with an AQ sticker
2-AQ sdc2.5 12's
1- AQ 1200D.1
Monster Cable RCA's
Monster Cable 4-awg
Custom 4 th order box ( by DBC )
Crescendo FT1's in rear- 1/0 Big Three
Opti Blue top in back for Mono Amp
Stinger Power dis. block
125 amp breaker at front batt.
Stock Alt.
Where's your turn on wire connected..... mine pop cause I hooked eq too ign rca signal Gets cut off before amp shuts off..I'm too lazy to change it lol
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Just add a toggle switch on your remote wire so you control when the amps turn on and off. That is if the problem is not cause by grounds,eq's etc. That way you can turn the amps on after the car is started and before the car is turned off.
its turn off/on pop its harmless.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
  • Who's Online   1 Member, 0 Anonymous, 718 Guests (See full list)
