Audiopipe APK 5500 guts
theChief
for $890 bucks its no piece of shit.
it will at least do rated at 14.4 at the VERY LEAST.
anyone wanna take guesses as to its output BEFORE efficiency?
ima guess like 5850 @ 13.3v if he burps it.
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Looks somewhat similar to the powerbass 5k also.
cause like i and another member said, its practically the same amp lol
i cant wait for the clamp results though
edit: do you have equipment to test for clipping to make sure the numbers wont be false?
I will be tuning the gains prior to testing with an Oscope.
said he had a scope i do believe.. at least i think thats what i read.
either in the first post.. or in the post where he says he has 250 amp mechman, etc.
09 Civic EX
KDC-X395
Stock 80 Amp Alt
Big 3 In 1/0 Knu
DD-1'd 13.8v drop
It does have very similar layouts to other amps, but that is not surprising considering its origin. Not to mention this is how many other amplifier companies operate. But the many engines are set up the same too, what separates them sometimes is not the science used, but the quality of parts used. The higher the quality, the higher the cost. And if Audiopipe ends up becoming a higher quality brand than they are now, the cost of their equipment will also rise which might go against the small niche they were trying to create.
Either way, tuned in for the results. Not wasting my time to clamp or test any of these newer amps.
Well just as an update the sound quality of the APK is much clearer than the AQX i had previously. It is hooked up and playing on 2 fifteens temporarily while i work on finishing everything. Once the build is done, soon i hope, i will do a series of burp tests. But so far with the gains set at a reasonable level the amp is clean as can be. I would compare it to a DC 5k that I've heard.
  • Who's Online   0 Members, 0 Anonymous, 563 Guests (See full list)
