Rockford Fosgate
Welcome to SMD Forum
t1500-1bdcp infrasonic filter question
This topic has been archived. This means that you cannot reply to this topic.
11 replies to this topic
#1
zero6391
zero6391
    120db
  • Members
  • 88 posts
Okay i have a rockford fosgate t2d415 hooked up to a t1500-1 at 2 puma and want to tune the box to around 29 Hz should i still use the infrasonic on the amplifier or no? And is it okay to build the ported box bigger than suggested in the manual?( manual says 4 cu. Ft but I want to go 5 cu. Ft if it will give me more air movement. My goal is to do a hairtrick with one t2)
Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car
#2
BassJunkie
BassJunkie
    No Thrill Unless Its Overkill
  • Members
  • 5,422 posts
Well you should wire at 2ohm and not 2 pumas, that could get dangerous.
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
#3
LT.Smoke
LT.Smoke
    Dedicated Family Man
  • Super Moderator
  • 13,344 posts
Can i ask WTF is "2 puma"
We have a new amp impedance rating???
** FYI Pumas are Gnarly ass animals and will F**K you up if provoked**
Edited by LT.Smoke, 07 April 2012 - 11:03 PM.
Si Vis Pacem Parabellum
Team Action Co captain
CnGraphix Factory Team VP
Bowhunting.com Team 16 Fatal Trajectory 2013 Hunting Team
http://www.stevemead...<< Accord Build
http://www.stevemead...la T-line build
#4
Katt
Katt
    Soccer Mom SPL
  • Members
  • 1,173 posts
Where do you buy these pumas you speak of my good sir? I want some for my setup!
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
#5
zero6391
zero6391
    120db
  • Members
  • 88 posts
Lol sorry I meant to say 2 ohms but for some reason my phone autocorrects the word ohms into puma
#6
RooTxBeeR
RooTxBeeR
    170db
  • Members
  • 5,769 posts
No, RF Power amps are preset to 28Hz SSF. If your tuning to 29Hz you will completely defeat the purpose of tuning that low. ALso general rule is to set a subsonic filter either 3-5Hz below tuning, so I would say try to tune to 31-32Hz with those subs if you would like to use the SSF
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
I'll admit, half way through sanding that fiberglass in the rain and cold while I was all itchy I was definitely starting to question why i was doing this haha
Old Deceased Build
'91 Honda Civic Hatchback
Current Build
'04 Ford Escape
1/0 SHCA Big 3 and 2 run to back
TORK2 kit from Tony @ CE Auto Supply
Pioneer DEH-80PRS
DD CS 5.2 in front
DD CSX 5.2 in back
RF P400-4
AQ750 @ 1 ohm
8.0Cuft box @ 32Hz
(2) 15" Skar IVX-15
#7
zero6391
zero6391
    120db
  • Members
  • 88 posts
Alright then thanks for the help on the filter but is it okay to make a big box and will it give me any advantages
#8
emperorjj1
emperorjj1
    170db
  • 18+ All Access!
  • 5,085 posts
yes
J. JPosted ImageMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS Posted Image
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
#9
zero6391
zero6391
    120db
  • Members
  • 88 posts
Okay what are the advantages of a bigger box?
#10
Katt
Katt
    Soccer Mom SPL
  • Members
  • 1,173 posts
Bigger box - less power.
Smaller box - more power.
Cant exactly remember why, but that's one thing to remember.
#11
RooTxBeeR
RooTxBeeR
    170db
  • Members
  • 5,769 posts
Bigger boxes are usually used when you are putting under RMS to the subwoofers and/or tuning low. The bigger airspace allows the subs to handle the lower power with better efficiency and handle the lows better also.
Old Deceased Build
Current Build
'04 Ford Escape
Pioneer DEH-80PRS
DD CS 5.2 in front
DD CSX 5.2 in back
RF P400-4
AQ750 @ 1 ohm
8.0Cuft box @ 32Hz
(2) 15" Skar IVX-15
#12
honolulublue
honolulublue
    120db
  • Members
  • 62 posts
i have the same sub but it is 2 ohms and running the 1000.1 bdcp, what tuning did you decide on building on
Edited by honolulublue, 20 May 2012 - 07:18 PM.
