Welcome to SMD Forum
2003 yukon denali with bose amp integration
17 replies to this topic
#1
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
So i want to install an amp in my friends yukon denali and it has bose premium sound and i want ti keep it stock but i cant find any integration units that say the specific model and year and that are compatible with bose so if u guys have any experience with them just point me in the right direction
#2
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
Anyone have any input
#3
matt14
matt14
    150db
  • Members
  • 1,981 posts
  • Gender:Male
Garage View Garage
Pac sells something to retain the factory amp when installing a aftermarket head unit.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemead...and-bats/page-3
#4
01ExSport
01ExSport
    125db
  • Members
  • 281 posts
  • Gender:Male
if i'm not mistaken, the escalade harness from pac was like ~$130-160. But yes, they do sell them. You could probably just enter your car into the crutchfield car selector and find it fairly easily.
#5
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
Well none of them says that they are compatible with a 2003 yukon denali with bose premium sound or if any of you guys know what wires to splice right after the stock amp to install a regular inline converter
#6
JasonJones
JasonJones
    140db
  • Members
  • 823 posts
  • Gender:Male
You'll want the GMOS-04 wiring harness. The head unit you go to install will need two sets of RCA outs for front and rear, and it he wants subs a third set. It will be able to integrate no problem at all.
Edited by JasonJones, 16 April 2012 - 07:07 AM.
#7
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
This could work but im planing on leaving the stock head unit in i just need like a line output converter thats has rcas for an amp that im installing
#8
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
So i installed the line output converter that i got at walmart and i hook it up the two front speakers and i am barely getting the subs to move idk if i did something wrong or if the output converter is low quality can any help me im installing it a in a 2003 yukon denali with bose premium sound
#9
JasonJones
JasonJones
    140db
  • Members
  • 823 posts
  • Gender:Male
You need to get a better LOC. I recommend the Axxess one. Also you tapped into the front drivers side positive and negative? And you got the midrange factory wiring right?
#10
blownengine
blownengine
    155db
  • Members
  • 2,127 posts
  • Gender:Male
  • Interests:Car audio, engines, wood working, engineering, everything cars
The Bose system has filters on it from the factory. If you tapped into speaker outputs then you won't get any bass because it is filtered out. You need to take off the side panel in the back and tap into the sub output.
My friend had the exact truck and I made the same mistake first time I installed equipment.
2003 Dodge Ram 1500 SLT (Yea its got a Hemi) Alpine CDA-105 KnuKonceptz 0ga CCA
Big 3 with Yellow Top
15" SoundQubed HDC3 DC Audio 1.2K (Bass) Pioneer 6x9's (Front) Pioneer 6.5's (Rear) Kicker 3.5's (Dash) Sony amp on the highs. (Hey it was free)
#11
Nasty1
Nasty1
    130db
  • Members
  • 317 posts
  • Gender:Male
U can use the loc u got just find the subwoofer + & - and bang away. Just remember that with bose systems the higher u turn it up the bass fades .
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz 19 cubes net 245sq in of port Sundown 3500 @ .7 Ohm Sundown 100.4 Rockford Fosgat Power Series 5.25 Dash 6.5 Kicks 8 Coaxils Doors 250 mechicman alt 1 red top under the hood 2 yellow tops in back big 3 with 1/0 knukonceptz wire 3 runs of +/- 1/0 knukonceptz wire IT LBS
#12
tejarillo
tejarillo
    120db
  • Members
  • 78 posts
  • Gender:Male
I tap the 2 front speaker both right and left idk if those are the midrange since the sub is inside the center console i think? I might be wrong
Reply to this topic
