Road to 150+ with single 15.
On my phone and have no idea how to multi quote, hispls, if I recall, when I was up at a 149, I had a 4 cu.ft. Box, 9 inch adjustable psychoacoustics port and the dd m3a, I got an aq 3500, put in a dowel in the box for bracing, I also went from 2 xs power batteries to 4 banks of caps, charging them to only 14.4 volts, that put me over a 150, I believe around a 50.3, once I ran the caps by themselves, charged them up to 15 volts, that put me over a 51. I think best score I got at home was a 51.3. I had a cap leak on me at finals, had to run only 3 banks. Right now, my set up sits at a 50.5, due to the new meca rules (have to have caps connected to your batt and alt and I have not bought an external regulated alt to charge up to 15 volts.) In the middle of building a 4.5 cu ft box, can't go really any bigger.
And yes, 80 amps of fusing off of the aq 3500, that's how meca classifies their classes, fusing between amp and batteries, you can run a bigger fuse or smaller, depending if you can get a good score out of that fusing, I could with 80 amps so I stuck with the class, you can check out their website for more info.
And you're talking about Kenneth correct? He's a very cool guy!
'11, '12, '13, and '14 Meca Street 2 AL State Champ
AL Meca Street 2 Record Holder(151.6)
2012 Meca Street 2 World Finals - 3rd Place(148.7)
2013 Meca Street 2 World Finals - 2nd Place(151.1)
I don't know too much about cap banks, is that 80 amp fuse between the caps and amp, or is it upstream of the caps? Just asking because even assuming perfect efficiency, 1200W/15V=80A, meaning you're getting nowhere near 3500, but maybe if there is no fuse between caps and amp you can draw some crazy current off those for a short period? That kind of seems like defeating the purpose of an 80A limit, but if that's how the game is played I guess add as many caps as you can fit.
2008 Subaru WRX STI
K&N Typhoon Intake
Invidia Polished Stainless 3" turbo back with cat
Cobb Accessport
Dyno tune from Kaizen Tuning
320awhp 330ft-lb awtq
MTX 421D Sub amp
American Bass SQ900 Highs/Mids amp
Sundown Audio SD-2 10 D4
JL Audio XR653-CS 3-way Components
3sixty.2
Second Skin Damplifier Pro
Custom fiberglass wheel well enclosure
Transmission Line quasi-floor enclosure
http://www.stevemeadedesigns.com/board/forum/13-member-rides-builds-show-off-your-whip-show-off-your-system/
Bill Fitzmaurice TLAH line-array hifi towers
9 Goldwood 4" mids (each)
12 Goldwood 1/2" tweeters (each)
NAD 1020 Preamp
MiniDSP 2x4 Balanced processor
Thorens TD166mkII Turntable
Hafler DH-200 Amplifier
http://www.stevemeadedesigns.com/board/topic/192638-line-array-hifi-tower-build/
https://www.facebook.com/HolyMountainGlass
Yeah Kenneth is the guy. That stupid car had a 50 in it but the fuses just wouldn't hold
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
david you phail at audio... your blazer is quiet..
oh and the cubs suck :)
This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
There is 80 amps of fusing between the caps and amp, the name of the game is find the fuse that lets through the most current. I ran a knukonceptz 80 amp fuse. I think that's what you were asking? I have not clamped it to see how much power I was getting, but my score jumped so I was happy lol.
I knew it probably did, sucks when that happens!
Hey now..... That's not nice! It is this year:-(
Hit up two shows this past weekend, Saturday show hit 150.6, Sunday was the Tennessee meca state finals, hit a 150.7. Here's the video from Sunday, took home second and first respectively. Not done yet....
niceee!
  • Who's Online   1 Member, 1 Anonymous, 925 Guests (See full list)
