getlocivic Posted June 15, 2012 Report Share Posted June 15, 2012 all personal preferance ive ran both aeros and slot ports.. i do prefer slot ports tho.. bc port acts as a brace etc.. and i hate taking time waiting on aeroports to get here.. general rule for aeros is 6 to 11" 12" per cubic foot and slot ports general port area should be in the 12" to 16" per cubic foot i like running more port than most people do ( i like 14 to 16" per)...im actually going to run 3 15s instead of 4 so i can get my desired 15" per cube.. Quote Link to comment Share on other sites More sharing options...
Paul Kadoshnikov Posted June 15, 2012 Author Report Share Posted June 15, 2012 all personal preferance ive ran both aeros and slot ports.. i do prefer slot ports tho.. bc port acts as a brace etc.. and i hate taking time waiting on aeroports to get here.. general rule for aeros is 6 to 11" 12" per cubic foot and slot ports general port area should be in the 12" to 16" per cubic foot i like running more port than most people do ( i like 14 to 16" per)...im actually going to run 3 15s instead of 4 so i can get my desired 15" per cube.. very true that the slot port does also play a role as a brace, but it also cuts away from the box area, and i make my own Aero ports, PVC pipe and a Gas heater and a simple butane can that slips inside the pvc pipe, then i press it against a funnel to create the lip of the pvc pipe, if its not enough i use a metal bowl and yeah, got my own aero ports. and can you define the 6 to 12 inches per cu ft. i have used Winisd and those box tuning programs, but the more port area the more air i move, so id rather hear you out before i go play with numbers. so say i make a 3 or 4 cu ft box, so a minimum of 18-24 in of port correct, so for a 4 inch wide port is 4*Pi*H = 18 to 24? but that gives me a port length of 2... which is wrong... Quote Bout to put in 2 21" Wardens on a taramps 8K Link to comment Share on other sites More sharing options...
Paul Kadoshnikov Posted June 15, 2012 Author Report Share Posted June 15, 2012 ^ above was trying to find the volume of the cylinder (aero port) which is Pi*r^2* H= Volume. so 3.14*4*H= 24 inch port simplifies to H= about 2... which makes me confused. im probably wrong, i dont know how to find aero port area.. Quote Bout to put in 2 21" Wardens on a taramps 8K Link to comment Share on other sites More sharing options...
Paul Kadoshnikov Posted June 15, 2012 Author Report Share Posted June 15, 2012 (edited) well the blue line is the JBL in its current setup and the green is the Re SX15... perhaps just keeping the jbl would be better... or perhaps making a better box for the JBL. what would be the better course Edited June 15, 2012 by Paul Kadoshnikov Quote Bout to put in 2 21" Wardens on a taramps 8K Link to comment Share on other sites More sharing options...
Paul Kadoshnikov Posted June 23, 2012 Author Report Share Posted June 23, 2012 already got the box started just need to assemble it now: http://postimage.org/gallery/xptl7ra/be6ae6c6/ Quote Bout to put in 2 21" Wardens on a taramps 8K Link to comment Share on other sites More sharing options...
