Enclosure design for 2 Sundown Zv3 12"
This will be in a scion tc 2006 hatch back.
Subs: Sundown Zv3 (1500rms) D1's wired in series to 1ohm
Amps: 2 Skar 1500.1's strapped
After box rise I want to be at 2 ohms or less
Max dimensions:
Width 41
Height 12.5
Depth 21
Currently I'm tuned to 27hz on 2 sa-12's and I peak at 39hz which is where Id like to stay for a peak. I'd go to 29 or 30hz MAX
I am open to aeroports or kerfing or slot port or whatttever.
Thanks for your time :D click the link in my signature if you want to see the current box
Edited by HunterJohnson
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Looking at your previous box it seems to me that when the hatch is closed the ports firing back are almost sealed back there, I guess that changing the port direction up (even with a turn) with that design would help.
I am weary to do a port up because I tried it with my alpine type x and it sounded like shit. Even tho they only have an inch of space it sounds really good. I think the best idea is to take an inch of the depth instead of shooting the ports up
Scion tC SQ Build
If you want sub up/ports back I would do something like this:
I would cover one of the 4" aero ports for daily and use all 3 to get loud.
thats looking sexy. I could even fix my current box to look like that. Do you know anything about putting subs as close together as possible to sound best/loudest?
Scion tC SQ Build
that box does not look good imo. Hunter, check your pm's i'm about to reply here soon.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Bear in mind that this is not a design, just a way out for the ports without taking much net volume. Yes there's plenty of infos around the internet about the increased acoustic power but I don't think that 2" more or less will change anything dramatically.
Step your game up to the 4500, son! this box will be perfect for that!
More box builds
  • Who's Online   1 Member, 0 Anonymous, 1183 Guests (See full list)
