SMD Forum: Rockford T15k - The Proto-pics (and Short Story) More Pics - SMD Forum
Latest Vehicles
34191_1339359408908_1378842284_30833996_4272172_n.jpgChevrolet Silverado 2500HD (2008)
Vehicle Owner: smokeumtires
Date Added: 07 August 2010 - 08:52 AM
05.jpgGMC Sierra (2002)
Vehicle Owner: Ray
Date Added: 29 July 2010 - 06:03 PM
Picture 048.jpgchevy astro van (1994)
Vehicle Owner: camaro6991
Date Added: 03 July 2010 - 06:13 PM
2010_07022008Feb0015.JPGMazda 3i Sport (2010)
Vehicle Owner: ptcary
Date Added: 03 July 2010 - 05:08 AM
9932_1239479109117_1293459821_30720699_6402457_n1.jpgChevrolet Silverado Ext. Cab Z71 (2005)
Vehicle Owner: Kryptic
Date Added: 02 July 2010 - 09:25 AM
Share Topic:   del-icio-us digg email facebook google mixx reddit stumbleupon
Page 1 of 1
Rockford T15k - The Proto-pics (and Short Story) More Pics More pics added 7/11/08
#1 User is offline   meade916 Icon
  • The SM in SMD
  • Group: Admin
  • Gender:Male
Posted 10 January 2008 - 10:00 AM
these were sent to me by my fellas at RF.....with their permission i decided to post them up for your viewing pleasure. I will add a few other of my own to help complete the visual since the proto pics dont look ANYTHING like a T15k does now :D
From Tony D at Rockford.....
This is a picture of the ORIGINAL prototype. At this point it had not been dubbed the "D'Fibrillator" yet. In fact at this point I had no idea if it was going to work or how much power it was going to make. If you look closely you'll see that there are 2 circuit boards back to back with about 2 inches between them. Those are output sections from T15002s. The MOSFETs used in the T15002s were not going to be able to handle the amount of power I wanted to put through them without overheating and blowing up so they are mounted to 2 inch aluminum square tube which had the coolant being pumped thru them. In the pic you can see the coolant reservoir and below it and to the left is the pump. We filled the reservoir with coolant that was in the freezer at 0 deg F and ice. The box underneath the output sections contained 12 motorcycle batteries all wired in series for 151.2 volts. Not pictured is the power supply that would convert 12V to 150V and charge them. (The T15kW runs at 136V in production trim). The MDF box in the picture is about 30 cubic feet ported with (4) T215D4s wired down to net (2) 1 ohm loads. Like I was saying I didn't know how much power it would make exactly so during the sound-off we had an Audio Precision system one connected to the output of the amplifier to measure its power. We made several trips through the lanes, each time I would push it a bit harder. First run was like 3000W 153db. Next run was around 7kw 156ish. Final round 10kw for a 158db at which point we had won. So because of this we decided to let it all hang out and see what she had. The result.... 15,030 Watts and a 160.3db. Thats how 15kW became the target. I just had to find a way to make it play music and not use motorcycle batteries. :)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
here is more to the story from a post ive had on my site for a minute or two :D
im tryin to get more pics out of him now :D
Yes it is true the idea came from a defibrillator. It seemed silly to me that all these guys in the db drag lanes need to have 1/2 of their vehicle full of batteries and alternators to maintain a decent B+ voltage for a few seconds. That and the fact that the amount of total energy all those batteries contain is huge and they are only using a fraction of it during their burp. It is like taking a NASCAR car to a drag race. A vehicle that is designed to go 200mph for hours on end probably isn't the best design for a 1/4 mile burst.
So when you look at the way a defibrillator is used its like burping an amp. Defibrillators don't have massive power cords that need mega amps at 220V, in fact some of them are portable and run off a very small battery. Why, because they don't need to shock someone for hours at a time, just a quick burst. They just draw a small amount of power continuously during 'charge up' and once all the energy they need is accumulated they release it all at once.
With the operation of the defibrillator in mind, I tried to apply it to car audio. I set off to build a prototype which was based on (2) T1500.2 output sections, I had to liquid cool the MOSFETs because even the FETs in the T1500.2's were not big enough to handle the kind of power I wanted. By keeping them very cold they could be pushed beyond their limits. (This may be the radiator ect... part of the story that someone posted). Then I needed a way to store a bunch of energy, electrolytic caps and some of the carbon based caps that are commonly used in car audio were not even close to being capable of storing the amount of energy I needed, so I used 12 small motorcycle batteries in series to get 140+ Volts. Then I built a power supply that would convert 12VDC to 140VDC to 'charge' these batteries.
I got this contraption all put together the night before the Annual Rockford Fosgate Employee Sound-Off. I didn't really how much power it would make exactly, but to try to shorten this long story it ended up putting out 15,030 Watts RMS! This is how 15k Watts became the goal for a 'real' amp.
The first step towards making it a 'real' amplifier was I had to eliminate the array of batteries. I began searching high and low for something that would do it. I found a company that makes capacitors for hybrid cars and large wind turbines. These worked perfectly. The caps I ended up using are 400 Farads, and there are 180 of these in the T15kW. Then I needed an intelligent power supply that could monitor these caps and add energy to them as needed, and it had to be fast, really fast if this amp was going to play music and not just a burst. So during music these caps are charging, discharging, charging, discharging. The power supply in the T15kW can charge the caps 35,000 times per second.
Of course many other things had to happen like finding MOSFETs that could handle it, a way to keep it cool without antifreeze and car radiators ect. The final product met all the goals and then some.
The main idea is that with this technology the amplifier can put out more power during transients or bursts than the car it's connected to could supply.
Again thanks for the props, look for hybrid technology to hit our smaller amplifiers in the near future.
PS if you guys would like to see pictures of the original liquid cooled proto I'll post them. This proto was eventually dubbed the D'Fibrillator. haha
Tony D'Amore
Design Engineer
Rockford Corporation
Posted Image
Posted Image
Highest OFFICIAL SPL scores (at shows, on the TermLab) -
DBDRAG - 156.5
Usaci - 157.4
Usaci Streetbeat - 155.2
Rockford Fosgate
Iraggi Alternator
ASCENDANT AUDIO!
XS Power Battery!
Wilwood Brake Co.
Second Skin Deadened
my YouTube Page: www.youtube.com/meade916 (all of my vids!)
www.SMDmedia.net !!
Myspace.com/smeade916
Facebook.com/meade916
Twitter.com/meade916
0
#2 User is offline   reinke Icon
  • ATTN WHORE
  • PipPipPipPipPipPipPipPipPipPip
  • Group: Deleted
  • Gender:Male
  • Interests:like everyonce else here
Posted 10 January 2008 - 10:02 AM
very nice. i would love to get one but one costs more then 3 of my cars. oh and btw steve dont look so pissed off man j/p
----reference's----
meade916
#3 User is offline   deezy Icon
  • 120db
  • Group: Members
  • Interests:Car Audio, Electronics, R/C Heli's
Posted 10 January 2008 - 07:23 PM
Damn!! :o That's just freakin' nuts. I was wondering how the whole 15kw came to be. I love to hear a good R&D effort turn up some useful results/technology. :D
Posted Image
0
#4 User is offline   Stephen Icon
  • 175db
  • Group: 18+ All Access!
  • Gender:Male
Posted 10 January 2008 - 07:48 PM
Posted Image
:rolleyes: B) :D :lol:
View PostDHFHades, on Dec 8 2009, 10:14 PM, said:
View PostGo-N-Def, on 14 March 2010 - 08:21 PM, said:
Posted Image
Posted ImageDC POWER
0
#5 User is online   kbreudi Icon
  • 135db
  • Group: Members
Posted 10 January 2008 - 08:14 PM
Wow very very very interesting...amazing how he got two small little 1500 watt amps to to 5 times there power.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
Posted Image
0
#6 User is offline   paul Icon
  • 130db
  • Group: Members
  • Gender:Male
Posted 12 January 2008 - 11:17 PM
Wow. I've just been schooled. That is some very interesting stuff there. Very informative too.
Yo Steve, does Tony D have any vid's of RF actually testing it out. I would love to see that prototype in action.
0
#7 User is online   IH8PunkRok Icon
  • annoying name
  • Gender:Male
  • Interests:My girl and bass
Posted 14 January 2008 - 06:40 PM
it started as 2 1500's? wow thats impressive
-Matt
JVC KD-AVX1
Cadence Xa 125.2 -> PG RSD 5.25's
PB XA 3000D -> DD 3512e
DB Elecrical 200 amp alt
Optima Yellowtop
Kicker CVR 15's build
DD 3512e build
0
#8 User is offline   meade916 Icon
  • The SM in SMD
  • Group: Admin
  • Gender:Male
Posted 11 July 2008 - 01:10 PM
more proto-pics came in my inbox today, figured i would add to this post....talk about Amp-Guts!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
thanks to Tony D AGAIN for the cool ass spy pics!! :ph34r:
Posted Image
Posted Image
DBDRAG - 156.5
Usaci - 157.4
Rockford Fosgate
Iraggi Alternator
ASCENDANT AUDIO!
XS Power Battery!
Wilwood Brake Co.
www.SMDmedia.net !!
0
#9 User is offline   David Icon
  • SleepinFart
  • Group: Admin
  • Gender:Male
  • Interests:Tattoo's and car audio, any questions?
Posted 11 July 2008 - 01:14 PM
SIIIIICK RF RULES
Living the sober life! 1 DAY AT A TIME
0
#10 User is offline   Sp33dyG Icon
  • "Teh Sp33dStA"
  • Gender:Male
Posted 11 July 2008 - 02:20 PM
View PostStephen_C, on Jan 10 2008, 09:48 PM, said:
Posted Image
:blink: :rofl:
View PostDavid, on Jul 11 2008, 03:14 PM, said:
SIIIIICK RF RULES
x2!! thats alotofpowah!
cant wait 2 see wut their new smaller hybrid amps gonna look like n how much power they gonna put out :blink:
Current system
1 Diamond Audio D161.5
2 Rockford T1 10" Dual 4
1 Hifonics BXi 1610D
Next System
2 AQ HDC3 10" Dual 1's
AQ 3500D
TEAM S.M.D.
TEAM TEX-FLEX
Posted Image
View Postmeade916, on 11 June 2009 - 11:10 PM, said:
the only person i wouldnt let build my box would be Ray.
0
#11 User is offline   meade916 Icon
  • The SM in SMD
  • Group: Admin
  • Gender:Male
Posted 18 July 2008 - 01:16 PM
the "latest topic" feature wasnt working when i posted this so how bout a fat TTT for those that didnt notice the cool pics i added to this post the other day ;)
Posted Image
Posted Image
DBDRAG - 156.5
Usaci - 157.4
Rockford Fosgate
Iraggi Alternator
ASCENDANT AUDIO!
XS Power Battery!
Wilwood Brake Co.
www.SMDmedia.net !!
0
#12 User is offline   reinke Icon
  • ATTN WHORE
  • Group: Deleted
  • Gender:Male
Posted 18 July 2008 - 07:10 PM
hell yeah those new pics are crazy
----reference's----
meade916
#13 User is online   qu1cks1lver56 Icon
  • 160db
  • Group: Members
  • Gender:Male
Posted 06 April 2009 - 09:44 PM
damn so they have 180 400 farad caps inside?
wow
My system:
CDA-9887
RF P450.4
RF T1k
RF Punch 6.5" Components
RF FNP 5.25" Components
MB Quart 3.5" Coax's
AA Assassin 8"
.4 cf sealed downfire
View PostDownSouthCustom, on Jul 8 2009, 02:56 PM, said:
Trust me .25 Blows your Load.
0
#14 User is offline   Bacy2k Icon
  • 125db
  • Group: Members
  • Gender:Male
  • Interests:cars, girls, money, music, tv, lifting, football, basketball
Posted 01 September 2009 - 08:35 PM
damn, this really makes you appreciate the t15k that much more... great post
Head Unit: Alpine CDA-9886
Door Speakers: Infinity Kappa Component 6X8's (4)
Rear Deck: Alpine Type-R 6X9's (2)
Mids/Highs Amp: Alpine MRP-F600's (2)
Subs: Alpine Type R 12's (2)
Sub Amp: Kole Audio KX1-5500D (1)
Battery: PowerMaster D3100 (1)
Wire: Streetwires Signal & Power Wire
Sound Dampening: Dynamat Extreme
0
#15 User is offline   bmongo18 Icon
  • 125db
  • Group: Members
Posted 27 July 2010 - 01:03 PM
Do they still sale the t15kw amp?
0
Page 1 of 1
Fast Reply
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
LaFountain Design | Professional Web Development
