Rockford Fosgate
Welcome to SMD Forum
Infrasonic filter Switch?
This topic has been archived. This means that you cannot reply to this topic.
4 replies to this topic
#1
gumedina83
gumedina83
    member
  • Members
  • 56 posts
i have a T500-1bdcp and i was wondering if i should turn the infrasonic filter on or leave it off my box is tuned to 35hz. i
#2
Skullz
Skullz
    170db
  • Members
  • 5,461 posts
If you have then use it, no fun bottoming a sub out cause you didn't bother to use the SSF built into the amp.
Set it just below your box tuning.
01 Ford focus ZX3
Pioneer AVH-X4700BS
Sundown SAX125.2
Hertz HSK 165
#3
Tarball
Tarball
    150db
  • Members
  • 1,910 posts
i would normally leave the filter off for a sealed box and for a ported you want it on and set just under tuning frequency.
With that particular amp you IF is hard set at 28hz. You may still get some unloading under tuning depending on the environment (and other variable factors).
Leave it on either way. If you get unloading adjust your volume or listening content.
Edited by Tarball, 01 September 2012 - 06:50 AM.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s-Project DB BusBar
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Subwoofers: 2 RE MT 15s  /PSI dual .7ohm recones
  • Subwoofer Enclosure:  9.1cubes @ 32hz - brutal.
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
    • Highs - 2 pair RE XXX tweeters (A pillar)
Build Log
Highest Legal Score: 149.9 db
Highest Musical 30 Second Average: 148 db
#4
rockFord_Expedition
rockFord_Expedition
    165db
  • SMD Gold Member
  • 3,866 posts
Short answer is ^ X2. Too bad it's either on or off and not adjustable, but with it being set @28hz it is fine for most applications.
What is your box tuned to? Are you using it for music only? I would say as long as you are tuned to 30hz or higher, and you are just using it for music then yes, leave it on.
Edit: just noticed you said tuned to 35hz
Edited by FunkyExpedition, 01 September 2012 - 06:16 PM.
#5
gumedina83
gumedina83
    member
  • Members
  • 56 posts
i use it for music mainly ill just turn it on and yeah i wish it was adjustable thanks for the help guys
