Pioneer~Saturn Posted October 23, 2012 Author Report Share Posted October 23, 2012 I got the caged portion almost to a 'finishing-work' stage today, poured another batch of resin+sand and then followed up with a batch with mat mixed in to level everything out (roughly) and get ready for final mat layers ontop... And finally got my first layer of 3oz mat layed down overtop of everything and overlapping onto the car's factory metal...roughed everything up with a wire wheel and also 40-grit sand paper beforehand and will be roughing everything up again before laying down more but that probably wont happen until the back is built up to the same height then it'll be finished with ~8 layers or so of 3oz mat :hello: :runaround: And yes, the side panels are taken off for this that run along the roofline on the sides of the car. I will be masking everything off near the end where they sit to do the final bodyfilling work and paint...then they will go right over any imperfections @ the seems Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..." Link to comment Share on other sites More sharing options...
Pioneer~Saturn Posted October 23, 2012 Author Report Share Posted October 23, 2012 Poured a couple batches of resin+sand today... I plan on CA-glueing a sheet/shirt from the car's frame down to the outer-top of the horn and wet with resin, once cured this will basically make a 'tub' ontop of the horn that I can go berserk on with no fear of it flowing anywhere :runaround: :hello: More when it happens... Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..." Link to comment Share on other sites More sharing options...
Pioneer~Saturn Posted October 23, 2012 Author Report Share Posted October 23, 2012 That poor saturn Tehehe, it's fine with it...it barely sees 50 miles per month these days anyways and still runs great. Took it for a spin the other day to test out the new roof Team Tupperware <First dual-alternator 'real' Saturn (pre-2002) on the planet>(3) 15" Fi SP4's fed by (2) M3a's strapped @ .66712.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)Stock alt position (custom bracket) 225 amp Mechman Roof = steel and fiberglass (u mad?)(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)4 power+ 4 ground runs of 1/0-gauge to rear"If its been done before...you're doing it wrong" : ) "stfu about scores and float $hit..." Link to comment Share on other sites More sharing options...
Pro7 Posted October 23, 2012 Report Share Posted October 23, 2012 I pray for your computer to get well soon cuz I am tuned into this build! I wanna see a build with sp4s and a lot of power!! I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before Link to comment Share on other sites More sharing options...
CortezDTV Posted October 23, 2012 Report Share Posted October 23, 2012 What the fuck did I just see someone cut their roof out? Wtf Then did I just see somone make a roof... Dear god what is going to happen in the rest of this build? SCSB Santa Cruz Speaker Box Build logs: Daily Driver Lemon Marquis 2 american bass 750.1s 350.4 on 14 focal 6.5s sq 945 on 4 hertz tweeters Mystery subs http://www.stevemead...__fromsearch__1 The Mustang 'dubbed' Shirley the project from bullet holes to badass http://www.stevemead...cond-skin-time/ Link to comment Share on other sites More sharing options...
bosslobbyz Posted October 23, 2012 Report Share Posted October 23, 2012 can't wait to see the rest of this build Link to comment Share on other sites More sharing options...
Scynte Posted October 23, 2012 Report Share Posted October 23, 2012 Holy fuck! Keen to see where you take this now.. Link to comment Share on other sites More sharing options...
graham0599 Posted October 23, 2012 Report Share Posted October 23, 2012 Idk what to think of this! It's crazy, keep it up. Box dimensions? My 350z build- http://www.stevemeadedesigns.com/board/topic/174424-2008-350z-build/page-2?hl=%2B350z+%2Bbuild#entry2605678 Link to comment Share on other sites More sharing options...
safiend Posted October 23, 2012 Report Share Posted October 23, 2012 Never seen nothing like this before, looking good so far! New build coming soon.. Link to comment Share on other sites More sharing options...
Bmike Posted October 23, 2012 Report Share Posted October 23, 2012 MORE !!!!! 2007 trailblazer lthead unit- pioneer p4300dvd crescendo ft-1 supertweeters pioneer m650 pros audiocontrol 2xs crossover Rockford fosgate p200-2 highsrockford fosgate p400-2 mids1- fi btl 18amps- saz 3500battery- evermax in front, 2 9a31 dekas in rearwires all knuconceptz 1/0 and rcas Link to comment Share on other sites More sharing options...
