Amps, Subs and Misc - new lower prices
Hey guys need a little help, found out I have pancreatic cancer and have ridiculous amount of hospital bills now. So I've grabbed up all the extra gear I have laying around. I'm really hoping I don't have to sell my current system.
I have a ton of 4 gauge wire and adapters, amps and other stuff I will post when I have a little more energy.
I have an old posting at http://www.stevemeadedesigns.com/board/topic/152013-wire-amps-dd-9518s/#entry2171178
most of that stuff is still around, sorry my chemo makes me very tired. I'll update as I can get energy.
First up 2 8" Rockford HE subwoofers brand new recones never seen power 90.00 plus shipping
">http://IMG_04421.jpg
Next are 2 Polk PA1000.1, brand new $200.00 each
  • PA Series Monoblock Class D Car Amplifier
  • RMS Power Rating:
    • 4 ohms: 500 watts x 1 chan.
    • 2 ohms: 800 watts x 1 chan.
    • 1 ohm: 1200 watts x 1 chan.
  • High-speed MOSFET power supply
  • Fully stable down to 1 ohm
  • Wired remote bass level control included
  • LED power (green) and protect (red) indicators
  • Variable Bass Boost (0 to +12 dB bass boost at 44 Hz)
  • Soft Start Turn-on
  • Mono channel operation
  • 1 Set of line level preamp RCA outputs to daisy chain multiple amps
  • 4-Way System Protection circuitry (thermal, DC offset, reverse polarity, and short circuit protection)
  • Heavy duty aluminum alloy heatsink for extreme heat dissipation
  • Nickel-plated RCA level inputs
  • Nickel-plated screw terminals
  • Variable low-pass filter (40-220 Hz)
  • Subsonic filter (20-38 Hz)
  • Damping factor: >150
  • CEA-2006 compliant amplifier
  • Frequency response: 20-200 Hz
  • Dimensions: 12-15/16"L x 6-3/4"W x 1-13/16"H
  • Includes 0 gauge power and ground adapter
">http://IMG_04431.jpg
Then finally for now Polk Audio PA500.4 never seen power $190.00 plus shipping
125 Watts x 4 continuous, 200 x 4 dynamic power (2 ohm load), 4 channel mode.
250 Watts x 2 (4 ohm) continuous power, 2 channel mode.
CEA-2006 compliant specifications for true, accurate power ratings.
4-channel, dual bridge-mono (2-channel), or dual simultaneous stereo/mono operation provide a variety of configurations and setups: 4-channel for front and rear speakers; 2 speakers and a sub; 2 subwoofers; or 2 subs and 4-channels in passive-tri mode.
2 ohm stable 4-channel operation.
High-speed MOSFET switching power supply and high current bipolar output transistors pump maximum voltage and high current to your speakers or subwoofers.
Double layer fiberglass epoxy printed circuit boards for more rigidity, less shrinkage and a smaller overall amp footprint.
6-way Smart System Protection (SSP) circuits
Fully adjustable (50-500Hz) 12 dB/octave high- or low-pass crossover. Defeatable for full range (flat) operation.
Switchable 8 dB bass boost at 40Hz for extra bass thump.
Variable input gain optimizes match with different signal sources (250mv to 7.5V).
RCA outputs (front channels only) for easy daisy chaining of other amplifiers.
Mounting hardware with rubber isolation grommets and extra fuses included.
Light bar/fan output-Connect an optional LED light bar or cooling fan for custom installations.
Multi-color status LED gives instant information on amplifier operation.
Remote subwoofer level adjuster for rear channels included.
">http://IMG_04451.jpg
I won this subwoofer in a raffle at a show a few years back, it's a 12" Almani S7. Has never seen power
rated at 3k probably take 1.5k rms. it's a beefy sub weights about 30 lbs
125.00 plus shipping
">http://IMG_0447.jpg
">http://IMG_0446.jpg
I have 6 of these 10" Polk Audio DB1040 dual 4 ohm, 270 rms.
60.00 each plus shipping
">http://IMG_0448.jpg
bump, please make offers. I hate to beg but I need to sale something so I can keep going until my disability kicks in. My pain meds and enzymes I have to take now cost me around 200 a month and they won't let me work until after all my chemo sessions.
PM me a price shipped for the 12" Almani S7 to 54667
www.facebook.com/BILLatDivineCreationsPhoto
He was taunting me. He's all like "come at me bro!" So I'm like "I'm coming at you bro!" And he's like "hey, fuck you" *chomp*. Then I killed it. I win.
^^^ you have truly taken being a lazy fuck to a new level tonight, an MRE. WOW
  • Who's Online   0 Members, 0 Anonymous, 1418 Guests (See full list)
