mnrookie Posted April 13, 2013 Report Share Posted April 13, 2013 RMS Power Output: 50 watts x 4 chan. @ 4 ohms 100 watts x 4 chan. @ 2 ohms 200 watts x 2 chan. @ 4 ohms Bridged Max Power Output: 800 watts @ 2 ohms Class A/B MOSFET Circuitry PWM MOSFET Power Supply Semi-double Sided Glass Epoxy Circuit Board 4-way Protection Circuitry: Thermal, Short Circuit, Overload and DC Offset Air Induction Cooling Fan Cobalt Blue Illumination Speaker level (high-level) inputs Preamp outputs Nickel-Plated Block Terminals Optional Remote Bass Control (Audiobahn ABR100T sold separately) Optional Remote-mount Digital Volt-meter display (Audiobahn ADM100T sold separately) Variable Bass Boost Control: 0-18dB @ 45Hz Variable Low-Pass Crossover: 50-120Hz Variable High-Pass Crossover: 50-750Hz Signal-to-Noise Ratio: 100dB Frequency Response: 10Hz-40kHz Variable Subsonic Filter: 20-50Hz THD: 0.02% Phase Control: 0 or 180° Input Sensitivity: 200mV-8V Dimensions: 9-1/8"L x 11-1/16"W x 1-7/8"H 8- or 4-gauge power and ground leads recommended. Link to comment Share on other sites More sharing options...
