Help? plus guts of the amp
imnew59585
Try searching around a little bit, I know there are a few companies out there that make replacement parts for amps. If you can find one of those "L" shaped pieces to solder back in that'd be the preferred method of repairing it. I would suggest having it professionally repaired but that might cost as much if not more than the amp.
ive seen it done before, if you feel comfortable doing it give it a shot
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
  • Who's Online   1 Member, 0 Anonymous, 1334 Guests (See full list)
