fosgatefan821 Posted July 17, 2013 Report Share Posted July 17, 2013 I got this today off craigslist 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery Link to comment Share on other sites More sharing options...
fosgatefan821 Posted July 17, 2013 Author Report Share Posted July 17, 2013 . 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery Link to comment Share on other sites More sharing options...
fosgatefan821 Posted July 17, 2013 Author Report Share Posted July 17, 2013 Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4V Mono into a 4W load 100 Watts Mono into a 2W load 200 Watts Mono into a 1W load 325 Watts 2-channel Bridged (using 2 Punch 50.1) into a 2W load 650 Watts Continuous Power Rating (Competition Standard) – Measured at 13.8 Volts RMS continuous power mono, into a 4W load from 20-20,000Hz with less than 0.05% THD 50 Watts RMS continuous power mono, into a 2W load from 20-20,000Hz with less than 0.10% THD 100 Watts RMS continuous power mono, into a 1W load from 20-20,000Hz with less than 0.3% THD 200 Watts RMS continuous power bridged, (using 2 Punch 50.1 Power amplifiers in the same system) into a 2W load from 20-20,000Hz with less than 0.3% THD 400 Watts Signal-to-Noise Ratio: >100dB (A-weighted) Frequency Response: 20Hz-20,000Hz ±0.5dB Bandwidth: 10Hz–250kHz ±3dB Damping Factor @ 4W (at output connector): >200 Slew Rate: 50V ms IM Distortion (IHF): <0.05% Input Impedance: 20k Ohms Source Unit Compatiblity (+15dB gain overlap): 28V max. input Input Sensitivity (+0dB gain overlap): Variable from 300mV to 5V Pass-Thru Output: Unity Gain B+ Fuse Size: (External to amplifier) 40 Amp or two 20 Amp Fuse Type: AGU Crossover Slope: 12dB or 24dB/octave Butterworth Factory Crossover Frequency: 80Hz (0.047mf) Factory Default Crossover Setting: Full Range Dimensions: 9-5/8"W x 13-9/32"L x 2-5/8"H (24.4cm) x (33.73cm) x (6.6cm) 2007 Ford Ranger (ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES) K&N Performance Air Intake Massive Audio D2400 Mono Amplifier 2 Custom Built 8" Subwoofers in Ported Enclosure Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed) 4 - Pioneer TS-A6886R 6" X 8" 2 - SMD Heavy Duty Single ANL Fuse Blocks 2- Stinger SPP1200 Dry Cell Batteries JL AUDIO Interconnects 2/0 Gauge Big 3 ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals ILL Customz 1/0 to 4 Gauge Power / Ground Reducers Factory Alternator __________________________________________________________________________________________________________________________________ 2002 Cheverlot Monte Carlo SS - (Deceased) 2 - Rockford Fosgate Power 1501BD 1 - Rockford Fosgate Power 851x Rockford Fosgate Power 6 1/2 Components Rockford Fosgate Power 3 way 6x9 2 - JL Audio W7 13.5" Subwoofers (Sealed) Pioneer AVH-P4400BH In - Dash DVD Player Pioneer AVIC - U250 - Add-on GPS Navigation System Audio Control 6XS 4 Way Crossover / Line Driver Ohio Generator 200 Amp Alternator 3 - Stinger SPP1200 Batteries 1 - Optima D34/78 Battery Link to comment Share on other sites More sharing options...
