gally Posted November 7, 2013 Report Share Posted November 7, 2013 all of the GZ amps are tested at 14.4V some of the biggest series like the plutonium series are tested at 13,8V 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
Bass_Maniak Posted November 7, 2013 Author Report Share Posted November 7, 2013 but with amp alone you could not get 151db... what subwoofers? box tune? car VAZ 2114, two subwoofers Ground Zero GZRW 38SPL, connection of 0.5 ohm. fighting box 49Hz Link to comment Share on other sites More sharing options...
Bass_Maniak Posted November 7, 2013 Author Report Share Posted November 7, 2013 Someone from Ground Zero was at the finals here in Alabama. They approached me and my teammate about running their amps. They have some big ones, but I do not like how they rate a lot of their amps on the website. That amp is rated as a 6000 watt max amp. This may be a problem for next years rules in DbDrag. Bass_Maniak, you said at the top 2500 watts @ 12 volts but the manual says CEA certified 2300 watts @ 14.4 1%THD Can you give some more detail about where your numbers are from? If you clamped it yourself, possibly a video? Here measurement amplifier with him, we measured and GZNA 1.2500DXII. Ground Zero GZNA 1.2500DXII showed slightly better results than Dragster daf 3001, only wish then got the battery in camera. Measuring Ground Zero GZNA 1.2500DXII application manufacturer 2300 watts RMS # 1 onm at 14.4 volts 1500 watts RMS # 2 onm at 14.4 volts that I intend to: 1) supply two stinger sp 2250 51 volts 50 amp 12 drawdown 2550 watts of power was measured with increasing voltage powered two Stinger 2250 and 2 volts bank havker 64 volts 61 amp 13.3 volts drawdown 3904 watts of power was Measuring DRAGSTER DAF 3001 application manufacturer 4000 watts RMS # 1 ohm at 16 volts 2500 watts RMS # 1 onm at 14.4 volts 1300 watts RMS # 2 onm at 14.4 volts that I intend to: 1) supply two stinger sp 2250 49 volts 50 amp 12.1 drawdown 2450 watts of power was measured with increasing voltage powered two Stinger 2250 and 2 volts bank havker 64 volts 60 amp 13.3 volts drawdown 3840 watts of power was here is a video http://www.youtube.com/watch?v=nXI7HhYR1ag http://www.youtube.com/watch?v=RRUvECI0rZI Link to comment Share on other sites More sharing options...
twisted1 Posted November 9, 2013 Report Share Posted November 9, 2013 Seem like bunch of bs... their large amps looks like most 2500s on market today 09 mustang gt Link to comment Share on other sites More sharing options...
Bass_Maniak Posted November 9, 2013 Author Report Share Posted November 9, 2013 Seem like bunch of bs... their large amps looks like most 2500s on market today do not understand you? Link to comment Share on other sites More sharing options...
gally Posted November 9, 2013 Report Share Posted November 9, 2013 Seem like bunch of bs... their large amps looks like most 2500s on market today do not understand you? its like you did that number with the GZNA 2500 amp..but on the other post you show how much the Dragster power was numbered....kinda not believable....(spelling?) also you claim that the -gz 2500 did almost 4000 of rms power at 0,5(which is kinda false---does around 3240 at max with a mechman 240 HO and 2 D3100 in the back at 13,8volts ) the second of all....all of the amp in exception of some of em like DD/ AQ and some of the others are tested i belive at 11,9-12,4volts if i am correct so unless those amps are tested at 11,9 those numbers are verry likely incorrect...as your statement is the dragster 3001 was also tested and is not stable at 0,5--it goes into protect after a couple of secconds of playing been there tried those amps... the only amps that are favorite by Ground zero are the plutonium series amps 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
Bass_Maniak Posted November 9, 2013 Author Report Share Posted November 9, 2013 Seem like bunch of bs... their large amps looks like most 2500s on market today do not understand you? its like you did that number with the GZNA 2500 amp..but on the other post you show how much the Dragster power was numbered....kinda not believable....(spelling?) also you claim that the -gz 2500 did almost 4000 of rms power at 0,5(which is kinda false---does around 3240 at max with a mechman 240 HO and 2 D3100 in the back at 13,8volts ) the second of all....all of the amp in exception of some of em like DD/ AQ and some of the others are tested i belive at 11,9-12,4volts if i am correct so unless those amps are tested at 11,9 those numbers are verry likely incorrect...as your statement is the dragster 3001 was also tested and is not stable at 0,5--it goes into protect after a couple of secconds of playing been there tried those amps... the only amps that are favorite by Ground zero are the plutonium series amps who not clear in the video!? everything is clearly visible! can daf 3001 and 0.5 ohm not stable but stable GZNA 1.2500DXII and 0.25 ohms for everyday listening to music! This is a vindicated and not just once! especially with the one we had GZNA 1.2500DXII in a sedan on the music 148 on 25Hz, and with the two amplifiers GZNA 1.2500DXII in the system with 4pcs 15 subwoofers we shot 154 at 30Hz. so that we know for ourselves that the amplifier GZNA 1.2500DXII proved to be excellent! and is a very reliable, stable low resistivity and a powerful amplifier. that tested more than once! And by the way dd M3a weaker than GZNA 1.2500DXII on a single system was a test, and M3a lost GZNA 1.2500DXII 1.5dB Link to comment Share on other sites More sharing options...
Jessica Posted November 9, 2013 Report Share Posted November 9, 2013 um, your avatar might be just a bit 18+. just sayin. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
gally Posted November 10, 2013 Report Share Posted November 10, 2013 Seem like bunch of bs... their large amps looks like most 2500s on market today do not understand you? its like you did that number with the GZNA 2500 amp..but on the other post you show how much the Dragster power was numbered....kinda not believable....(spelling?) also you claim that the -gz 2500 did almost 4000 of rms power at 0,5(which is kinda false---does around 3240 at max with a mechman 240 HO and 2 D3100 in the back at 13,8volts ) the second of all....all of the amp in exception of some of em like DD/ AQ and some of the others are tested i belive at 11,9-12,4volts if i am correct so unless those amps are tested at 11,9 those numbers are verry likely incorrect...as your statement is the dragster 3001 was also tested and is not stable at 0,5--it goes into protect after a couple of secconds of playing been there tried those amps... the only amps that are favorite by Ground zero are the plutonium series amps who not clear in the video!? everything is clearly visible! can daf 3001 and 0.5 ohm not stable but stable GZNA 1.2500DXII and 0.25 ohms for everyday listening to music! This is a vindicated and not just once! especially with the one we had GZNA 1.2500DXII in a sedan on the music 148 on 25Hz, and with the two amplifiers GZNA 1.2500DXII in the system with 4pcs 15 subwoofers we shot 154 at 30Hz. so that we know for ourselves that the amplifier GZNA 1.2500DXII proved to be excellent! and is a very reliable, stable low resistivity and a powerful amplifier. that tested more than once! And by the way dd M3a weaker than GZNA 1.2500DXII on a single system was a test, and M3a lost GZNA 1.2500DXII 1.5dB actually IF you see...you DECLARED THAT gzna 2500AMP TAKES THAT POWER AT 1OHM...THEN CHAANGED AT 0.5, AND NOW AT 0.25 i call bullshit that amp i not stable at 0,25 as i know because i used to have that F amp...0,5 is the lower you could go...with a proper amount of electrical supply oh just for shit and giggles...we tested in a audio shop on a show car...the M3a...at 13,9(with drop voltage) it was tested 3704watts of power im not getting argues about which one is better, because then it would become a VS thread.. if you are a GZ nuthogger then so be it... the seccond of all...you tested at what? clamping and proper dyno testing are 2 different things...so unless it was on a dyno...dont belive that crap 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
gally Posted November 10, 2013 Report Share Posted November 10, 2013 also the thing is....when driving and bumping at 3/4 of volume...you will never get the rated 14,4volts.....which the GZ and Dragster amps are tested--- except if you have A High Output alternator and a battery bank 2010 Chevrolet Cruze Radio --- pioneer mvh-200vbt Front/back --- alpine type s 6.5" Sub Control --- Pac LC1 Sub Amp --- GZPA 1.4K Sub --- GZNW 15XSPL D1 Battery - GZBP 12.2500X Link to comment Share on other sites More sharing options...
