T-Series Amplifiers HAVE ARRIVED!
Yes! We are happy to say that all our T-Series amplifiers are OFFICIALLY fully stocked and ready for shipping! The T-Series consists of 2 monoblock amplifiers and 2 5-Channel amplifiers and are all very impressive! The 4 new models in this series are all very well built, high performance, and conservatively rated amplifiers. They also feature several nice design features, such as Tiffany RCA connectors, blue LED Lighting, and a very efficient heat sink for maximum heat dissipation.
Pricing is as follows for these fantastic amplifiers:
T-60.4-200.1AB - $329.99
RMS Power @ 1 Ohms : N/a
RMS Power @ 2 Ohms : 80 Watts x 4 CH + 350 Watts x 1 CH
RMS Power @ 4 Ohm : 60 Watts x 4 CH + 200 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~40kHz
Input Sensitivity : 6V~0.2V
Low Pass Filter : 50Hz~500Hz
High Pass Filter : 80Hz~4kHz
Subsonic Filter : 15Hz~50Hz
Bass Boost (Variable) : 0dB~12dB
Signal to Noise Ratior : 100dB
Damping Factor : ~180
Fuse Rating : 30 Amp x 3
Remote Gain Control Included with Knob
Line-In RCA Connection
Line-Out RCA Connection
4 Way Protection Circuitry
Dimensions : 250mm x 53mm x 420mm
T-60.4-500.1D - $399.99
RMS Power @ 1 Ohms : N.A. (4CH) + 500 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~40kHz (4CH) 10Hz~250Hz (5CH)
5th Channel is 1 Ohm Stable (4 CH is 2 Ohm Stable)
Dimensions : 250mm x 53mm x 400mm
T-1400.1D - $329.99
RMS Power @ 1 Ohms : 1400 Watts x 1 CH
RMS Power @ 2 Ohms : 700 Watts x 1 CH
RMS Power @ 4 Ohm : 350 Watts x 1 CH
Frequency Response : 10Hz ~ 250Hz
Input Sensitivity : 6v~0.2v
Low Pass Filter : 50Hz ~ 250Hz
8 Gauge Power and Ground Terminals
Dimensions : 250mm Wide x 53mm High x 340mm Long
T-2000.1D - $549.99
RMS Power @ 1 Ohms : 2000 Watts x 1 CH
RMS Power @ 2 Ohms : 1000 watts x 1 CH
RMS Power @ 4 Ohm : 500 Watts x 1 CH
Frequency Response (-3dB) : 10Hz~250Hz
Low Pass Filter : 50Hz~250Hz
Fuse Rating : 200 Amp (External)
Dimensions : 480mm x 53mm x 340mm
Skar Audio
www.SkarAudio.com
Phone : (888) 501-7527
  • Who's Online   0 Members, 0 Anonymous, 1546 Guests (See full list)
