skaraudio Posted October 22, 2013 Report Share Posted October 22, 2013 The brand new T-Series Series amplifiers are a brand new product line from Skar Audio, and with that being said we wanted to get some clamp testing done to go alongside our SMD AD-1 Amp Dyno results with these amplifiers, so you have a variety of tests to see their power output capabilities... Testing conditions/setup was identical on both amps, allowing for an easy comparison between the line. We are very happy with the results, and this will give you a baseline reference point when browsing and choosing from the compact amplifiers on the market. Only the Monoblock Amps in the T-Series line have been tested so far, which is the reason for the exclusion of the 2 new 5-Channel models. We will test and post those results shortly! Head Unit Volume : 60/62 Head Unit Sub Level : 6/6 Test Frequency : 50 Hz Test Load : (1) ZVX-12 D2 resting @ 0.8 Ohm Test Electrical : (4) Non-Charging Shuriken SK-BT75 12v Batteries Amp Gain Set Level : 1/2 ------------------------------------------------- Skar Audio T-1400.1D POWER OUTPUT : 1325 Watts (calculated) AMP CURRENT : 27.6 A (measured) AMP VOLTAGE : 48.0 V (measured) ACTUAL IMPEDANCE : 1.74 ohms (calculated) SUPPLY VOLTAGE : 12.86 V ------------------------------------------------ Skar Audio T-2000.1D POWER OUTPUT : 2365 Watts (calculated) AMP CURRENT : 37.6 A (measured) AMP VOLTAGE : 62.9 V (measured) ACTUAL IMPEDANCE : 1.67 ohms (calculated) SUPPLY VOLTAGE : 12.48 V Skar Audio www.SkarAudio.comPhone : (888) 501-7527 Link to comment Share on other sites More sharing options...
Soccerballzs Posted October 22, 2013 Report Share Posted October 22, 2013 Looks Good! Keep up the good work!! http://www.stevemeadedesigns.com/board/garage/vehicle/2438-jeep-commander/I Pioneer P99RSAmpere 38002-Ampere 125/44-6.5 inch Hertz HSK XL Mids4-8 inch JL Audio ZR Midwoofer 2-5.25 Satori Mids2-Morel Tweeters, 2 Hertz Milles 3 inch on A pillars2-Hertz Silk tweeters DC Audio Level 5/12 Skyhigh Wire Mechman 320 XS Power D3100MO Funniest Thread of the Year 2013: http://www.stevemead...dy-being-a-pos/ Link to comment Share on other sites More sharing options...
