Kid With a Dream Posted November 6, 2013 Report Share Posted November 6, 2013 Hi car audio noob here. I seem to have a problem with my fuse holders melting- I'm on my second one. My first fuse holder (T-Spec V6) was a cheap POS and in a bad location so I moved it and got a higher quality one(T-Spec V12). Well my second one melted so I took it to my local Car Toys and they told me that the problem was with my cheap power wire(T-Spec V6 1/0 CCA power wire). He compared mine to some Stinger 1/0( that he was selling at $7 a foot), and I could see that mine was definitely not as high quality. My issue with this is that I'm not pulling that much power... Only 140 amps-1600 watts. Even the cheapest 1/0 gauge should be able to handle that right?? He acted like that was a lot of power but to me that doesn't seem like anything to me. My question is what else could be causing it to melt like this? Also, whats the best power wire out there? Keep in mind this is a growing system... I'm planning on 7,000+ RMS. Any help/advice would be awesome. Thanks! Sorry the pics are f-ing huge I couldn't figure out how to put them in. I'm forum noob too/: My first fuse holder.... My second fuse holder... Link to comment Share on other sites More sharing options...
justin0943 Posted November 6, 2013 Report Share Posted November 6, 2013 heat is cause of low voltage and loose wires I never had problem when I was running db link ofc 4ga to the rf t1000bd the reason why is the screw type fuse holder had a buddy to use them rf and kicker it always got hot an almost melts the plastic bought a pos bolt type never had a problem.also it could be the wire 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/ Link to comment Share on other sites More sharing options...
FeelDaBass Posted November 6, 2013 Report Share Posted November 6, 2013 They tend to loosen every now and then. Loose connection = voltage drop = heat. '98 Chrysler Concorde LXiPioneer DEH-80PRS (HU/processing)Rockford Fosgate T1652-S (components) for frontRockford Fosgate T1693 (6x9s) for rearRockford Fosgate T600-4 running thoseRockford Fosgate T1500-1bdCP running a Rockford Fosgate T1D215 15"in a 3.1 cu ft. net tuned to 34 hz (firing in cabin)Kicker PKD1 (0 & 4 AWG)stock 130 amp alt for now; One yellow top OptimaInstalled everything myself & built box (brother helped) Used a DD-1 to set gains. Build Log: http://www.stevemeadedesigns.com/board/topic/165894-first-build-accumulated-since-i-was-14/Just Pics: http://www.stevemeadedesigns.com/board/garage/vehicle/1463-chrysler-concorde-lxi/?tab=images Link to comment Share on other sites More sharing options...
Skullz Posted November 6, 2013 Report Share Posted November 6, 2013 They are junk! Use fuse holders that require lugs to be attached to them so they do not loosen over time and heat to the point of melting. The main reason those fuse holders loosen over time is the rocking of the engine and ever so slight tug on the wire causing it to loosen just enough to increase the resistance. 01 Ford focus ZX3 Pioneer AVH-X491BHS PPI PC 4800.2 Morel Maximo 6.5" x2 Link to comment Share on other sites More sharing options...
timc31610 Posted November 8, 2013 Report Share Posted November 8, 2013 100% Loose connection. Like Skullz said, a lug type holder is less likely to loosen. If you want to use the cheaper ones I have had success putting a dab of thread sealant on the screw before tightening it. Just dont put too much or it may get between the wire and the screw and cause the same problem. My Build Log 94 Civic http://www.stevemeadedesigns.com/board/topic/188644-94-civic-4-door-build-loq-suggestions-wanted-will-be-super-slow-mo/ Faceebook reluctantly Link to comment Share on other sites More sharing options...
BigManAC Posted November 8, 2013 Report Share Posted November 8, 2013 Go on eBay and find fuse holders with bolts, they are around $5 a piece and will come with what fuse you need. I haven't had a problem yet with them. As far as the best power wire goes there are many good brands. Knuconcepts and XS Power has power cable but the best out there with the highest stand count is Sky High Audio. Good luck man with the build. 2001 Saturn L200-Sony MEX-BT4100PFRONT STAGE:- (4) Crescendo PWX 6- Cadence XA250.2SUB STAGE:-Fi Audio BL 15 (Sealed Off)-Crescendo BC2kELECTRICAL:- Singer 240A alt - XS Power D3400- SkyHigh OFC power/speaker wire- Big 3 with SkyHigh 0gaugeBuild Log: Click HereScores: 146.5db @ 29hz Outlaw Link to comment Share on other sites More sharing options...
HunterJohnson Posted November 8, 2013 Report Share Posted November 8, 2013 you can also make your own and use locking nuts http://www.delcity.net/store/MEGA-Fuse-Holder/p_795652.h_795653.t_1.r_IF1003?mkwid=7WlUPe7j&crid=8229606509&gclid=CM2myZGU1LoCFap7QgodaCkAWA something like this won't losen up and cause voltage drop Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass Link to comment Share on other sites More sharing options...
