louVega Posted November 19, 2013 Author Report Share Posted November 19, 2013 Where in Vegas??? Link to comment Share on other sites More sharing options...
louVega Posted November 22, 2013 Author Report Share Posted November 22, 2013 For those interested I was sent spec sheet from Zenon Audio for XL3KD. Digital Class-D linkable mono block amplifier Dual MOS-FET PWM power supplies Daisy-chain through output Jack Double sided through hole epoxy PCB Stable into 1 ohm and 2 ohm parallel amplifier connection 24dB/oct variable crossover Variable 24 dB low pass (LPF) crossover Variable Bass Boost Variable phase shift Variable subsonic filter Efficiency : 86% @ 4 ohm, at 100Hz Multi-way protection circuitry (thermal/over current/speaker short/speaker DC protection) RCA line input Heavy duty copper layer double sided epoxy PCB Zero(0) gauge power supply connectors Tested voltage & THD : 14.4V & less than 1% THD Operating voltage : DC10V~16V Wired remote control Rated power output @14.4v 1020wx1 4 ohms 1900wx1 2 ohms 3050wx1 1 ohm 3600wx1 4 ohms strapped 5500wx1 2 ohms strapped Signal to noise ratio -------------> 90db Low pass freqency crossover 30hz-250hz subsonic filter---------- 10Hz~30Hz Bass boost @ 45hz------- 0~12dB Bass boost Frequency----30hz-90hz Phase shift control ------0-180 deg Frequency response-10hz-350hz (+/-1db) THD@RMS watts <1.0% Efficiency @ 4 ohm 86% 300A (external type fuse) 200mV ~ 6V (+/- 5%) 250(W) x 58(H) x 520(L) Link to comment Share on other sites More sharing options...
Andreetje77 Posted November 26, 2013 Report Share Posted November 26, 2013 This one looks very mutch the same; http://www.stevemeadedesigns.com/board/topic/178810-flatline-fl2/ Link to comment Share on other sites More sharing options...
louVega Posted December 6, 2013 Author Report Share Posted December 6, 2013 Wow that amp does look very simila,r 77 Link to comment Share on other sites More sharing options...
