99 Civic, 2 DC LVL 6 18s, NO WALL, PICS AND VID 5/28
yooo, Ive been lurking around on here but never have joined to post, but I figured I would share this next build with you guys. Here is what it consists of....
1999 Civic Hatchback
161,xxx miles
D16 motor
pretty much all stock, lowered front and rear about 2 inches
2009 Civic Si exhaust
manual everything but will be converted to power due to custom doors being built :nuts:
Equipment list:
HU: Pioneer 80prs ran to a Ipad Mini in the dash, secondary source will be a ipod in case i dont have the ipad
Mid bass: Exodus Anarchies
Mid Range: Crossfire 10s
Tweets: 2x Crossfire tweets, Eclipse 3" midrange
Amps: 2x Ampere 3800.1s, 2 Ampere 125.4s
Subs: Level 6 18s
Electrical: Dc XP 270 amp alt, 4/0 and 2/0 welding cable, 1 XS XP 950, 2 Eaton 135 ah's, 2 banks of Maxwell 3000 Super caps
gonna have some other cool custom fabbed shit like a SMD VM-1 :BART:
still in the process of gathering gear but the build will start slowly now then get serious in about 2 weeks when Im home from college for a month.
heres a pic to hold you guys over until then, Ill be starting the dash mod for the ipad very soon, however.
1C8F342F-F567-4E06-BA4A-98BF24CDE501_zps
sounds like a good build man. need more power for those lvl6's though :)
*** SuperSeller Status Verified *** ( http://www.stevemeadedesigns.com/board/topic/25829-super-sellers-buyers/ )
"kevosinn's" astro van
8 custom Sundown Zv4 18's
4 Sundown scv 6000's
CNF Distribution CNC parts
Skyhigh wire
some batteries
SMD Meters and tools used on the install
http://www.stevemeadedesigns.com/board/topic/172877-kevosinns-vanwest-coast-skyhigh-car-audio-vehicle/
16,000 watt walled silverado build.
http://www.stevemeadedesigns.com/board/topic/161965-walled-silverado-4-hdc4-15s-4-crescendo-3500s-and-much-more/
8,000 watt 1999 Subaru legacy outback. Build log here: http://www.stevemead...ru/page__st__60
TEAM CNF Distribution
lol, depending on electrical woes i may try to double up but we shall see.. starting the ipad dash in the next few days,
The Om-1 i picked up on the black friday sale! gonna flush this into a center console im building
A8A34F7C-755C-4CBA-9F3A-458D66D07C9F_zps
B80917FA-D5DB-4F93-8406-F83685278F97-146
OH, and did i mention i plan on tuning to 30
  • 3 months later...
80prs and Pac LC-1 knobs, will have one on the subs and the other on the exodus anarchies
490FF0A3-6666-4E20-AC3B-409510B18CC7_zps
2" eclipse mid ranges i will be running up in the pillars
A20F2074-93FF-4968-AA09-7DD5E53D06CB_zps
start of the console, this used to be a CD holder and BS cup holder that would hardly hold a coke can, worthless! so i modded it to house my 80 prs and smd OM-1 to make room for the ipad in the dash.
1E77C64F-95A1-4693-9E8D-0ADCD85B8E56_zps
sizing it up
BA9EE72C-A220-4613-BD0B-A23507884FED_zps
2C8AF60C-09C5-4695-B1BB-45CF46FA179B_zps
66E944CA-3DE9-45C1-B5FC-3DF0B369F3E3_zps
it was cold as hell so i had it close to the space heater, went inside to take a duece and when i came back outside i found this, **** near ruined the whole thing... oops
18CDACB2-0DEB-4E99-92AA-B5F312D57AA2_zps
brought it back though, plastic welded some abs in there then used a lil bit of bondo to shape it back correctly, pain in the a$$.. stupid mistake on my part
30F75082-2A1D-49E5-B314-7493597260A1_zps
getting there
57B1E2F0-75B2-421A-ADA0-AA0943C7E61E_zps
bish needed a tune up so i changed out all the plugs,dist cap, plug wires, oil, did a cold air intake, few other things..
plugs were nasty
D9768C25-6E9B-4980-86C2-3AD1D2E32CA2_zps
4940F678-E506-47D7-A714-830BF272E0F6_zps
yikes!
CC50F80C-767B-431B-B096-C0BF7DE73BF7_zps
0F88D559-F71E-4127-9F28-E8B455EE0176_zps
ipad dash on the way
F1943C27-1261-47B5-B79A-F008A8D4491B_zps
deadener
938806CC-E1FA-4DEB-85CB-FBE45D4F20D1_zps
812D8ED9-1364-4D73-A793-7EF790A82328_zps
deadened the ***** out of the hatch
AE6B8DAD-78AE-43AE-BD16-B515220E875D_zps
took off the door panels to begin removing the manual doors to find this... the car was swimming at some point in its life for sure there was so much dirt and sand i vacuumed out of this car.. oh well, nothing i cant fix,but i got new doors all together with better paint and all the electric components inside so i began swapping that shiz over
30273710-E3BC-4189-AD9A-BD5C2F49D5F0_zps
plugs were nasty
yikes!
deadener
beginning of the door swap
598C7637-AEAC-452E-AB80-28A7FC51F3E8_zps
door off
52E078AB-FABD-4D5D-88F6-8C9DFA3BAEDF_zps
switching the locks and handle mechanism over to the new door
5BD70FF6-0348-4532-86DE-442956F25B12_zps
had to make my own harness, routed it through the door with loom and cust the grommet, did alot of silicone on the back side to keep moisture out, its actually looks pretty close to factory.
F696ABEB-5DD9-4C9A-A27F-9C9DCB534029_zps
all tip tied and glued
0E30BD22-9056-4C01-B6C9-3FCB099DB072_zps
buttoning everything back up
16DEF100-76FC-4196-8819-6B09514992BE_zps
start of the doors
64C9477C-79E6-465A-A1A4-AB21800AB55B_zps
10" ring in place, i want these to be flush like the factory panels are, they will be wrapped in tweed and look **** near stock.
08640025-4345-4605-89EF-B08609E8C902_zps
anarchy ring in place, both flush mounted
255380E6-AC4C-4EBA-AC85-5F445D03D82A_zps
holes drilled so the resin will seep through and grab onto the plastic
7C36A049-1524-4D89-AC8A-58351C621C03_zps
wrapped and resined
59D27C6B-0AE1-4447-B8CF-44A41D30FCCD_zps
other door
CE3552AE-D4CF-4DC8-92AC-4C68844DA1FD_zps
B96D1321-141F-453A-A6A3-481BBC9FF3FA_zps
used amazing goop to secure the rings to the plastic, used two tubes of that stuff, it cures hard as a rock the rings arent going anywhere!
FB466626-64A6-415F-A69D-0A3977606565_zps
resined and trimmed out around the rings
F42CC8DD-EBF5-471C-8FF9-8515D8D0CE23_zps
wrapping the second door
D381F0CE-2B10-425D-B870-ECB4B07D87A9_zps
XS XP 950
C524AB01-B0BC-4907-876D-1110E468BA60_zps
DC Audio hoodie to match my build, got it from CJ18 over on SMD
753834A2-AF34-4B53-8100-0892DB8AF266_zps
gonna do these carbon caps on the subs with a white dc sticker on top
62a51e33-6802-455f-a905-b200e1defd9e_zps
started building the floor, framed out with 2x4s
4DEDF8D4-44A7-4D4E-ADDE-C4FCCC177A2F_zps
frame done
52334161-ECCD-4882-ACBA-79A3C4A940BC_zps
started doing a template out of cardboard to follow all of the contours
77D16795-D316-46D2-8BAD-EE25956A2444_zps
traced it over to teh mdf
05E92114-1F4C-438D-B783-93EE860573F8_zps
cut out
735C5E9C-38D7-40D8-A8A2-1742F101FEC0_zps
got it all in, in one piece! came in though the driver door, gonna build some of my box outside the car then slide it in and screw it all tofether, will be much better than building it all in the car
9B5A4E5B-2A54-4A4C-BB03-AFF8E8266014_zps
custom DC sign
BC216776-E0FB-46CC-AF30-791F4D0FC9F5_zps
8 gauge ofc for direct leads and aux power in the car
254B8A84-2C14-4E3E-A67A-4113802193AD_zps
bad *** controller i have for all my leds and the dc sign, 2 sets of 1/0-4 gauge reducers for the 4 channels.
BFC1AEAD-DA08-48F5-9240-62D2ADC18470_zps
techflex for all my wire, will look really clean and nice
67B0FFC0-9792-4B5E-A24F-D2C7BEE12726_zps
tweed for the doors
2AEAF046-93CB-416F-9977-D47EEE0B4415_zps
and thats where i am right now, subs and amps will be here this week. its about to finally all start coming together
  • Who's Online   0 Members, 0 Anonymous, 1206 Guests (See full list)
