XS Power
Around 4500 rms system.. 250 amp alt and xs3400d in front. help
Would it be ok if i put a xs3100d in the trunk of my car? Would my alt be able to supply enough power for the 2 batteries? Also is is ok to have a smaller battery in front and a bigger one in the back? I would like to just put a 3400d in the trunk also instead of the 3100d if that would be enough power.
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
Granite Crystal Metallic Exterior
Inferno Red Interior
5.7 HEMI AWD
LMI Air Hammer Intake
Corsa exhaust
Custom Tune
Please give all info, alt, under hood battery? Wiring, big 3? amps? etc. etc. vehicle...
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
If this is for daily and you have a 250amp alt along with the 3400 upfront, then you would be fine with putting another 3400 in the back. Now if this is for competition or demo use, then putting the D3100 in the back or an XP300 would probably be better.
Of course the Big3 upgrade will help either way!
http://www.sonicelectronix.com/item_74887_XS-Power-BIG3XS.html
Edited by Nathan@XSPOWER
04 grand marquis, 250 amp alt, big 3 done 1/0, XS 3400d under hood, cresendo 3500d, soundqubed 125.4, mb quart 80.4, 4 gauge wire going to the speaker amps fromk batt, 1/0 going to the sub amp from batt. lights dim pretty good at full tilt. gains are set correctly.
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
It is a daily driver but i do go to some competitions, Oh and my car hates volts, ive changed the alt twice, i can put it in drive and volts will drop pretty low and than when i hit the gas the volts go back up. It also did this with the stock alt cause i know some H/O alts volts at idle are lower.
Edited by Marquisboys
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
I would put a d3400 up front and 2 d3100s in rear minimum. U would be better if u put 3-4 d3100s in rear though . I had in my tibi 327 amp alt big3 1/0 2 runs 1/0 OFC d3400 upfront and 2 d3100 in back on dc5k and 300 watt mtx amp
On 3/28/2014 at 4:22 PM, KyLar96 said:
Its all about the music anyway..... Do a proper install, something your happy with, Fuck everyone else...... improve in time, where you can..... its not rocket science...
Tiburon build //www.stevemeadedesigns.com/board/topic/174059-97-hyundai-tiburon-build-from-ramming-to-slamming-slow-5k-build/
2000 Mountaineer build http://www.stevemeadedesigns.com/board/topic/186736-2000-mountaineer-build-from-ramming-to-slamming-part-iislow-5k-builddc-audio-americanbassxspowersingerarcaudiostingershcavideo-on-pg7/
2000 Mercury Mountaineer: Electrical:Singer 360 hairpin powdercoated white alt, Big 4 double run 1/0 SHCA OFC, 4 runs 1/0 OFC SHCA, limitless 70ah, HU: Pioneer deh80prs interiors: Skar sk85.4 on sb acoustics neo dome tweeters 2 Mmats sq4100s on 4 silver flute 8s(4ohm) SUB Stage: 3 DC5K [email protected] on 6 ascendant audio mayhem 12s d1.4s fully loaded
So the XP3000 would be better than the 3100d?
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
People are getting battery happy here lol.. with the alt you have you can run a d34 up front and an xp3k in the back and be perfectly fine bro. just be sure to use all the same wire to link the batts. what are you running your amp at? 1 or .5? how many runs of 0ga do you have? do not purchase 2 d31s for the rear when you are only running a nendo 3.5k . with the 2 batts mentoned above you would have 185 AH, not to mention the beefy 250Amp Alt you have. bass on my friend
But What Do I Know?
2003 Chevy Monte Carlo SS 3.8
  • JVC KD-R975BTS
  • Clarion EQS746
  • Kenwood P907PS
  • Ascendant Audio 12" Havoc v.1
  • Ampere Audio 2000.1
  • MB Quart Onyx 800.4
  • XS Power D3400 - Hood
  • XS Power D975 - Trunk
  • Singer 240A
  • Sky High OFC 0 & 4 gauge
  • Kno Knoise Kolossus Deadener
  • 1 month later...
Yeah firgured more than on batt in the back would be overkill lol i just have the amp at 1 ohm and just one run of 0ga. Im thinking of trying out the Crescendo 31 group battery seems like a good deal.
2004 Grand Marquis
AA Mayhem 18
Crescendo 3500d
6.5's AQ Pro Audio
AQ Super Tweets
Image Dynamics 6x9
Soundqubed 125.4
MB Quart 80.4
144.2 db
GONZO
2013 Chrysler 300S
5.7 HEMI AWD
Corsa exhaust
Custom Tune
Heard its better to pair the same brands of batteries and not mix and match brands. I'd stay with XS for the trunk.
97 Buick LeSabre with stock 140 amp alternator
XS Power D3400 (under the hood) using pdb distro blocks
Big 3 done with 2/0 ga welding cable
Alpine CDE-HD149BT head unit
CT Sounds Meso 6.5" components
CT Sounds 60.4
CT Sounds 1400.1
Fi Q 12 D2 with cooling in 2.5 net tuned @32 hz (box built by Sound Mekanix Customs)
Bunch of Sky High 1/0 ga & 4 ga cable (plus fuse holders)
Connection BT2 & BT4 550 (Audison) RCA's
Bunch of Mojo Mat
  • Who's Online   2 Members, 0 Anonymous, 1485 Guests (See full list)
