zero6391 Posted April 11, 2014 Author Report Share Posted April 11, 2014 here is a close up pic of the panel got the other pods put on i used a garage door seal that i got at home depot to create the lip on the rings got the panels wrapped ready to glass, this is my first time fiberglassing anything my supplies to glass got the first layer done got the 2nd layer on Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
cj92 Posted April 11, 2014 Report Share Posted April 11, 2014 nice keep up the work.. I like the car and respray color . New Build 92 Wagon http://www.stevemeadedesigns.com/board/topic/193327-back-with-a-new-build-1992-taurus-wagon/ Old 2005 Ford Mustang Build http://www.stevemeadedesigns.com/board/topic/174628-05-mustang-build-update/ Check out my Old build 98 Honda Accord http://www.stevemeadedesigns.com/board/topic/163280-1998-honda-accord-build/ Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 nice keep up the work.. I like the car and respray color . thanks for the props, i still have another year to catch up on as far as pics lol its just taking forever to upload these pics cuz there is so many Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 here are the single shots of each panel and driver side rear panel time to resin the back of the panels and rings a pic of the panels after the glassing took out the amp rack to put in the back panels got the panel put in! they aint sanded yet also to build a frame in the above pic i got two pieces of 2X4 and then got two bolts to screw them down using the bolt hole from the rear seatbelt thingy's. here is a pic of the driver side panel in too after the test fitting i cut out the speaker holes and started putting in my component sets Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 its starting to get dark which slows but not stops my progress lol as a little side project i upgraded the big three ground cables to 0 AWG wire my engine ground Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 time to make the amp plates i cut the holes to run the power and speaker wires on the amp rack getting the stands screwed on getting the wires ready getting the wires run thru a pic of the relay i made to turn on the amps and signal processor. i used a bosch 30 amp 5 pin relay close up shot got the rack set in i got both batteries hooked up now Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 time to hook up the processor Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 i set the gains using a DD-1 got two amps in got the last amp in, the processor was faulty so i had to send it back in so in the meantime i used the passive crossovers Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 another little side project, i sanded down the ground for the front battery to keep the bare metal from rusting the finished product Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
zero6391 Posted April 12, 2014 Author Report Share Posted April 12, 2014 time to hook up the volt meter the volt meter ill be using taking out the stereo to run the wires under the center console dusty back there how i ran the wires finished, dont freak out this is just a temporary spot until i can build a instrument pod Pioneer AVH-X5500BHS, (2) Rockford Fosgate T400-4, (4) Rockford Fosgate T1652-S Component Sets, (1) Rockford Fosgate T1500-1BDCP, (1) Rockford Fosgate T2D415 in a ported box (5.5cu. ft. tuned @ 37Hz), (1) Optima Yellow Top under hood, (1) Shuriken 80 amp batt in the back, 2 runs 0 AWG OFC Rockford Fosgate wire, Big 3 upgrade on front and back battery, Stock Altenator (90 amps), RF RCA's, Kicker 12AWG OFC speaker wire, Stinger roadkill sound deadner all over the inside of the car Link to comment Share on other sites More sharing options...
