Kyblack76 Posted April 18, 2014 Report Share Posted April 18, 2014 Chevy 4.3 Shitty start (have to add gas and it takes a good amount of turning it over to start) Idle is hell, rough I'd say. Just drove it 200 miles and it was all cool but all the above) Gas mileage I dunno if it's lost or not. Now, there is a smell. A smell from the exhaust. Mmmmm not really bad, sulfur maybe?? Just changed plugs and wires. (STOOPID plastic clips that hold plug wires where the worst part of the job!!) Cleaned TB and EGR valve. No go. I'm putting it on a scanner in 25mins. Thought anyone? SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
n8ball2013 Posted April 18, 2014 Report Share Posted April 18, 2014 Could be ignition coil distributor cap or rotor cracked. THERE IS NO BUILD LOG! 1998 Chevy Silverado ext cab Alpine CDA-9887 4 Team Fi 15s 2 Ampere Audio TFE 8.0 2 Ampere Audio 150.4 3 Digital Designs CS6.5 component sets Dual Mechman 370XP Elite alternators inbound! 8 XS Power d3400 6 XS power d680 Second Skin Stinger Tsunami Wiring Sky High A Real Voltmeter not a piece of shit stinger. Link to comment Share on other sites More sharing options...
omg_spoon Posted April 18, 2014 Report Share Posted April 18, 2014 Could try cleaning the MAF sensor. Check fuel pressure too. Just to make sure. Reseting computer is always a good idea too. Just yank the ecu fuse for a min or so 98 Mustang GTSinger 3202 12" Incriminator Death Penalties1 SAZ-2500dv22 D3100,1 D34002 Crescendo CZ-65SAX-100.2Door panels by Diablo Kustomz Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 18, 2014 Report Share Posted April 18, 2014 What n8 said or your fuel pump is starting to go Link to comment Share on other sites More sharing options...
rTisTik Posted April 18, 2014 Report Share Posted April 18, 2014 If the vehicle was sitting over the winter something could have crawled up the exhaust and well, died, or built a nest of some sort. Could explain the smell and rough starting and idle. But I would expect a big power loss if this was the case. IDK just a shot in the dark. Link to comment Share on other sites More sharing options...
cookscustoms Posted April 18, 2014 Report Share Posted April 18, 2014 do you mean you have to add throttle input to get it to start? Or actual fuel in the throttle body? 2010 dodge ram cummins t1000bdcp dc audio xl12 p400.4 pioneer avh-3500bhs Link to comment Share on other sites More sharing options...
JEFFYBOI Posted April 18, 2014 Report Share Posted April 18, 2014 Could be so many things... Poor idle could be Mass air flow sensor. Throttle position sensor. Idle air control valve/sensor. Dirty throttle body or its sticking. If the fuel pump is going bad you should be able to put a fuel pressure gauge on the fuel rail or somewhere close to check your fuel pressure. Now if you got a funny smell going on that's the big concern I would worry about, check your oil and coolant make sure you don't got the chocolate milk fluid in your oil. If you got a blown head gasket or intake manifold gasket you can get coolant into your oil and visa versa. Typically signs of a blown gasket are poor running bad gas mileage poor idle and stinky white smoke from Exhaust. Good luck "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS Link to comment Share on other sites More sharing options...
Ahmed Johnson Posted April 18, 2014 Report Share Posted April 18, 2014 The car would overheat fast off a blown gasket Link to comment Share on other sites More sharing options...
JEFFYBOI Posted April 18, 2014 Report Share Posted April 18, 2014 The car would overheat fast off a blown gasketYes it would overheat after a few days of driving it with a blown gasket ( depending on how bad its leaking). If he is just now noticing it, it may be to early to get overheating symptoms. I had a blown gasket on my 02 buick for several days and it never overheated, I actually found it was blown because my low coolant light came on and I had discovered it was going into my oil... It was a hell of a job replacing that thing. "Toyota Camry rebuild page 21 (link)http://www.stevemeadedesigns.com/board/topic/183768-94-crossfire-camry-18s-walled-singer-alt-has-arrived-rebuild-starts-pg-10/page-21 PIONEER DEH-P8400BH 2 CROSSFIRE C5 1700D 2 CROSSFIRE C7 18 HOOD. NSB GROUP48 TRUNK SMS AGM400 DUAL RUNS X SCORP 1/0 OFC 275A SINGER ALT. DYNAMAT XTREME SOUNDSTREAM TA4.280 PIONEER COMPONENTS Link to comment Share on other sites More sharing options...
ProMaxx316 Posted April 18, 2014 Report Share Posted April 18, 2014 Just did tune up?? Started happening after tune up. Maybe firing order is off. Misfiring long enough can cook up the cats and give that nasty sulfer smell. Check cap,rotor, dizzy. The long start issue. I think it was common for most of the blazers that use spider injectors that would give you a long/delay in starting. Also same for fuel pump. Pump not sending enough pressure to start unless you primed first then crank over. If it's worth building, it's worth over building. Link to comment Share on other sites More sharing options...
