2013 Altima 3.5 (Rockford Prime, Digital Designs, DC Audio, JL Cleansweep) **New Stuff**
My name is Mike and this is my Altima. I started dreaming up ideas right after I got it. It does have Bose and factory HU touchscreen will be retained. I'm doing this in stages and I work slooooowww.
Here is the car.
Pennsville-20131025-00067_zps7c306043.jp
I like to use Sketchup to visualize and fit things before I start building. So, I created my car and some different sub ideas.
This is a T-line I thought about.
Another idea 12" ported.
Another with 2 SA-8s.
So I decided on the SA-8s after hearing and seeing so many great reviews.
This would fit right into the opening to trunk with seats down.
So I started building the box in the Fall.
Then I changed my mind and decided to do just a single 12" and switched to DC Audio subs.
Redesigned the box.
reworkedSA8boxtofitsingleported12withpor
Then started modifying the box.
Decided to extend the ports a bit to give more clearance to the port in the box and I think it makes the box look better.
Glued some mdf together.
Bought myself a big 'ol round over bit for the port opening.
Damn you are good at sketchup haha!
Plans look promising!
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
So I kerfed a piece of mdf for the top of the arch.
Pennsville-20131202-00113_zps83464e10.jp
then decided it was going to take a lot of filler and sanding so I switched it up and used Sonotube instead. I cut a section and glued and screwed it to the top.
Pennsville-20131211-00116_zps8710b609.jp
A little SunFlash resin to help deal the cardboard. It was 32 that day.
Pennsville-20131211-00117_zps127fc0a6.jp
Pennsville-20131211-00118_zps88243cbf.jp
I skipped some pictures in between and with the hard winter we had in NJ, it was impossible to get things done since I have no garage. I have do all my work outside or in my shed.
Here it is with top installed and primered.
Pennsville-20140202-00143_zps0443f543.jp
Pennsville-20140202-00146_zps856bf2d2.jp
While this sat during the snow storms, I ordered my sub and wire and began some electrical.
Nissan uses a fused block connected to a very flimsy battery terminal. I didn't like it. So I started planning how to add wires and lugs to this thing.
Pennsville-20130917-00061_zpscda474ab.jp
Here is the Sketchup (I told you I design everything first)
I machined up a little aluminum adapter and threaded it.
then I ordered some marine terminals and drilled out the post as it was too short and put a 3/8" stainless bolt in there.
Here it is ready to go.
Order a Big 3 kit from Tony C!
Pennsville-20140313-00004_zpsc9baa6a9.jp
Started replacing the battery terminals and wire.
Pennsville-20140315-00007_zps8deeebee.jp
Pennsville-20140315-00008_zpsf0d90380.jp
Pennsville-20140315-00009_zps5bb1328c.jp
Time for charge lead and ground replacement.
Pennsville-20140316-00012_zps27c6bae0.jp
Pennsville-20140316-00017_zpsbc341595.jp
Pennsville-20140316-00016_zps3c164a96.jp
Pennsville-20140316-00015_zps2e6a403a.jp
As the weather broke, I started to run wire to trunk.
Pennsville-20140405-00024_zpsf20bda29.jp
Pennsville-20140405-00026_zpsd8ff84f6.jp
Pennsville-20140405-00025_zpsbdf7b855.jp
ran the wire right into the spare tire well. Grommets.
Added some ground lugs.
Pennsville-20140425-00046_zps3d91b78e.jp
See the brackets? They will attach another piece of mdf that spans the trunk. It will serve a purpose.
My car has a trunk organizer.
Hmmmm, could I use that for somethin? Yes...however, Id like to keep that intact. So, I made one to fit.
Pennsville-20140413-00029_zps83f6d974.jp
Now its fitted and the sub in place. Need to mark it for a hinge so I can access the spare. Here's how it will fit.
Good looking Nissan. If you found a better way to get to the alternator post than i did, please let me know. I'm assuming by the picture that the 3.5 is identical to the one put in my car and engine is transverse. That L bracket thing is a great idea but are you worried about disregarding the red battery cover? I'm also in the process of switching from my fiberglass boxes to a wood box firing into the cabin. I can't fit my golf clubs in the trunk without folding down the seat.
2009 Nissan Maxima SV Super Black KH3
  • Hardwired Beltronics 955 Radar
  • Pioneer DEH-M9400BH with Stock Bose Speakers
  • Custom fiberglass HVAC display
  • Nexus 7 Tablet w/ Custom Fiberglassed Magnet dock
  • KnuKonceptz Big 3 and wiring
  • 2 Alpine Type E 10's with Alpine MRP-M500
Build Log HERE
  • Who's Online   2 Members, 0 Anonymous, 1448 Guests (See full list)
