94 Ford Beast-350 OBS CCLB - Motor is done, need to sell, questions-please help
Well this has turned completely around since the first time I started it. It's no longer an audio build log, as well as performance build log. It's really just turned into a motor rebuild and that's it. Sorry folks. My wife and I bought an 06 F250 with the 6.0 Powerstroke (I know about the issues) and that is going to be my truck from now on. Actually it's turned into a sort of daily driver. The civic is gone now. That chapter is over. My wife and I carpool in her new car, so this is really my everything else truck.
But, in the meantime, in order to do the things I want to do to it, audio, and performance, I have to sell the beast. But, I can't sell the beast until I get her up and running again. So that's what this thread has turned into. I'll leave the stuff below so you all can see what's been done to it so far, up until this motor overhaul. SO hopefully you all stay tuned, and follow this. It's the first time i've ever gotten this deep into a motor, and it's been an amazing learning experience.
I've done a couple of other builds on this truck, audio and otherwise. Those links are below:
RSK Suspension Lift
1994 Ford F350 CC Build
Old UBL (I'll start another one for this)
I think that's it. The UBL has the temporary build I did in it.
So this is a 1994 Ford F350 Crew Cab Long Bed 4wd. It has a 7.5L 460 in it. Auto locking hubs (which I'd like to change to manual but they're pricey to do). It's the XLT version. She's got 117k on her as she sits right now. I've got a long list of things that I've changed in her already, take a look:
Full brake system rebuild:
Brake Master Cylinder,
Front Calipers,
Front Brake Pads,
Brake lines (swapped over to SS lines when I did the RSK),
RAB Sensor,
Rear Brake Drum Cylinders,
Rear Brake Pads,
Flushed Brake Fluid,
Speed Bleeders
New 3G alternator - old one caught fire causing this, and as a result - New Radiator hoses, new wiring, new belt.
New Power Steering Pump and Reservoir - AGR Performance
New Steering Gearbox - AGR Performance
New Steering linkage
Rebuilt Transmission E40D
PMF 3.5" Reverse Shackle Kit up front
Super Duty Leafs all around
PMF 5" rear lift blocks
Billstein 5100 Series Shocks all around
New Energy Suspension Bushings
New PMF Adjustable Panhard Bar
New PMF Drop Panhard Bracket
New Pro Comp Drop Pitman Arm
New Crown Stainless Steel Braided Brake lines
New A/C condenser
New A/C lines
Banks Power Pack - Includes: Ram Air Intake, K&N Air Filter, Banks Exhaust Tube Headers, 3" Stainless Exhaust, Magnaflow Muffler, 4" Banks Exhaust tip
Stage 8 Stainless Steel Header Bolts (won't back out)
New Bosch O2 Sensor
New EGR Tubes
Oil Cooler Bypass: Removed the oil filter adapter from the block, removed the oil cooler box, added a new radiator hose to go from the radiator to the block bypassing the box that's no longer there.
Summit Dual Oil Filter Remote Location Kit (adds 2 oil filters and re locates them off the block)
Pro Comp 33" AT Tires
Gear Wheels (I have no idea what kind I got them off craigslist when i bought the truck for the tires they had on them for $150)
Rear Differential Fluid Change
New Motorcraft Fuel Filter
New Motorcraft Ignition Coil
New Thermostat
New Distributor
New MSD Ignition Coil Cap and Rotor
New Motorcraft Ignition Control Module
New TPS Sensor
New EGR Valve and Sensor
New Skyjacker Dual Steering Stabilizer
Done During Rebuild:
Machined OEM heads
Valve seals
New Gates Water Pump
New Water Pump Backing Plate
New Cloyes Timing Gear and Chain Set
New Timing Cover
New Harmonic Balancer
New Motorcraft Spark Plugs
New Ford Racing 9mm Spark Plug wires
New Gates Belts (there are 2)
New Edlebrock Head Bolts
New ARP Component bolt kit (this is basically the set of bolts that covers about everything around the motor, throttle body, water pump, timing cover, alternator, etc)
New Gaskets, head gaskets, head cover gaskets, water pump, timing cover, oil seal, throttle body, etc.
New Motorcraft Oil Filters (2 for dual Filter kit)
New PCV Valve
New Temperature Switch
New Temperature Sensor
New IAC Valve
New Air Temperature sensor
New Idle Air Control Valve
New Hoses
New Vacuum Lines
New Saginaw Power Steering Pump (replaced the AGR Performance Noisy PSP I put on when I got the Gearbox)
New Transmission Filter
Full Transmission fluid flush and replacement
Rear Differential Fluid change
New Battery
New Battery Positive, and all grounds wire replacement
New Radiator
New Flex-A-Lite Fan
Full Fluid Flush and Replacement
A/C Recharged
Cleaned intake
Cleaned throttle body
Rebuilt Fuel Injectors - using Mr. Injector parts
That's all I can think of right at this moment. I may be missing something. Let's just say, she's basically getting a complete overhaul. I'm a little sad to be selling it at the end of all this. Who knows, maybe she'll run so well, I'll sell the F250 instead. LOL, I doubt my wife will ever agree to that. She has a well known hatred for this truck. Look at the parts list and you can see why. But to me, it's something to be proud of.
Thanks for hanging out, let's get this party started!
Tuned!
Where's the pics? :unknw:
Is it done yet....WTH
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
Dash mounted O-scope
Highs Amp - PPI Art A404
DC Audio DC9.0K
2- DC Audio XL12m2
JUNE 2014 SOTM WINNER
SOTM BUILD:
This should get interesting. Your works always on point.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
:ttiwwop:
Haha jk bro just bustin your balls! I know they are comin....sounds bad ass tuned in FTMFW!! Let's get to it!
Funny how the people who have a louder system than you will usually give you a compliment about your setup because they know how much blood, sweat, time, and money you put into it. The people who criticize or try and one up you....have a p.o.s to no system at all and will tell you all about this "other" guys system! Saddley I'm sure if I meet this "other" guy...he will probably tell me he thinks your just as annoying as I think you are!
I'm not compensating, just proud of fabricating!
My build log: 10k center console with 4 DC Audio XL 10's powered by 2 DC Audio 5.0k amps 5 xs batteries and dual DC Power 300xps alts
http://www.stevemeadedesigns.com/board/topic/169404-goodvibez-04-dmax-10k-center-console-w4-xl-10s-custom-5ksit-plays/page-19
Ok guys I need some input. What should I call the Facebook Page for the truck. Like the civic was loud and low because it was lowered and it was loud. Pretty self explanatory. Should I continue with the theme on that and call it Loud and Tall F350 or something like that? Hit me up, what do you think?
So I made a little goof with my enclosure. I was originally trying to do it in the truck box. I have two angles at the bottom of the box because of the way the bed angles. I tried to stay within those angles which is about 55" wide. But with the port, 7" wide plus 1 1/2" for port walls, then 48" minimum for subs, and then double walls on the outside, I just don't have enough room. I need a minimum of 62.5" to make it work like I'm thinking. I was thinking about doing a center port and then 2 subs on each side. But now I'm contemplating two other designs. You all know how I like to be different.
But I think I'm going to nix the truck box all together and just build it since I'm going for a bed cover or shell anyway. I think I've decided on the shell. I'll just build it, then fiberglass the hell out of it inside and out and then hit it with some bed liner and I think it'll be fine, on top of the fact that it'll be inside of something.
I am worried about taking too much out of the back wall however. So my other two design thoughts are these:
First I was thinking about doing a big long port on the bottom of the enclosure laying horizontally, and then subs on top of it. But in order to get the 34 hz I'm looking for, it's got to be either really thin, or I'll have to shrink the width down.
The other thought I have is splitting the port and going one on each end. So the port I had for this was 14.5" tall and 7" wide and 22" long (I think) for a 34hz tuning. If I did it this way I'd split it and do two 3.5" x 14.5" x 22" ports at each end with the subs in line in the middle. This is pretty much what I have now, and it works.
I may do any of the three although I think the port on the bottom is going to be hindered by the batteries. I'm planning the batteries to be on the floor in front of the subs until I can build some frames and mount them under the truck. I guess I could go on top with it.
Just throwing out ideas here. Anyone have any thoughts or suggestions or anything out of the box they've always wanted to try? I'll take in mind any you wanna throw out there.
Dunno if I have good enough knowledge on port and box to give good advice...
...as far as a name
the "Bass Face Ford"
or Idk "Blow Flow Ford" BFF for short haha jk dont use acronyms ;)
I'm sure you could come up with something better!
  • Who's Online   1 Member, 0 Anonymous, 1782 Guests (See full list)
