evermaxx Posted May 19, 2014 Report Share Posted May 19, 2014 funky pups too. Team Subsonic Lows Get your garbage EMF products of my amp bitch Man....it makes a nice work bench Link to comment Share on other sites More sharing options...
conbon Posted May 19, 2014 Author Report Share Posted May 19, 2014 thanks guys! 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
oldsoundguy Posted May 19, 2014 Report Share Posted May 19, 2014 Soundqubed makes a HDC3 dual 2 ohm sub its just not in stock right now. I would look at the HDS300 series and the price is real good. Only rated at 300 RMS less than the HDC 3. 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
conbon Posted May 19, 2014 Author Report Share Posted May 19, 2014 Soundqubed makes a HDC3 dual 2 ohm sub its just not in stock right now. I would look at the HDS300 series and the price is real good. Only rated at 300 RMS less than the HDC 3. do you think itll be okay to over power it that much? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
EP95 Posted May 19, 2014 Report Share Posted May 19, 2014 As long as its clean power, yeah 300 watts is nothing. Link to comment Share on other sites More sharing options...
oldsoundguy Posted May 19, 2014 Report Share Posted May 19, 2014 What amp are you using? 80prs Arc Audio Xdi 1200.6 (using active crossovers) Freaking awesome amplifier Incriminator IA 10.1 Focal PS 130v 5.25 (doors) 4" Faital pro Neo (kick panels) 3" Faital pro Neo and focal tweets( dash) DC Audio level 3 12" custom box designed by joex built by me AGM front, XS 750SE batteries rear DC 180 alt 99 Toyota Tacoma extra cab http://www.stevemeadedesigns.com/board/topic/179476-my-small-build-turned-into-the-ongoing-build/ Link to comment Share on other sites More sharing options...
conbon Posted May 19, 2014 Author Report Share Posted May 19, 2014 What amp are you using? rockford t-1000 but id wire to 1 ohm so its 1500 watts 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
conbon Posted May 19, 2014 Author Report Share Posted May 19, 2014 As long as its clean power, yeah 300 watts is nothing. what do you mean by clean power? 2013 Ford Focus Hatchback SE Kicker CS61234 Kicker 40CS674 Kicker KST25 Sundown Audio SA-12 D2 Rockford Fosgate t1000-1bdcp Rockford Fosgate t400-4 Audio Control LC7i Kinetik HC2000 0/1 Gauge Big 3 Upgrade Beer, babes, and bass. Link to comment Share on other sites More sharing options...
azscott Posted May 19, 2014 Report Share Posted May 19, 2014 By clean power he means not to send a clipped signal to your sub, set your gain properly using a dd1. It's a great tool to invest in. Link to comment Share on other sites More sharing options...
Agreene Posted May 19, 2014 Report Share Posted May 19, 2014 look into sundown sa-12s. i had a pair of sundown sa 12s in a box about the big and tuned to 35 hertz was wonderful.. they played low lows and still could play dubstep when i wanted to Link to comment Share on other sites More sharing options...
