tacomaguy1 Posted June 21, 2014 Report Share Posted June 21, 2014 Not sure if its a problem or not but want to check 7 3100s Not sure what they were resting at when I plugged it in, but set it at 15a and let it go Went out this morning and its still charging 14.4v(no problem there, been 2 weeks or so didn't expect them to be done) but switched it to read amps and it was at 2 something? Should it be charging at a higher amperage than that or does it keep it low for some reason Tried to switch to 25a to see what it would do and charger went to error Quote Team Flex Issues Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 21, 2014 Report Share Posted June 21, 2014 (edited) EDIT - i just read that you swapped to amps, and had a question. My bad. Also, when you go from 15 to 25 FAST, the charger will fault, cuz, well your bat is charged, It sees your 12v bat, acting like a 14v, and thinks YOU hooked up a 14-16v bat.... feel me? ... wait an hour, and restart it at 25amp Edited June 21, 2014 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 I hear ya Just didn't know if it charging at only 2a was normal Quote Team Flex Issues Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 21, 2014 Report Share Posted June 21, 2014 I hear ya Just didn't know if it charging at only 2a was normal ya.. i just re read that, and thats why i scratched my shit... that, i dont know. I would expect time would make that happen. I would imagine that is normal. Why you havent hit second stage yet, is a lil worriesum to me ?!?!!? Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 21, 2014 Report Share Posted June 21, 2014 the only time it took more than 2 days for my bank to go from 14.4 to floating at 13.4 was cuz i left the fucking dope light on....... other than that, now, it takes about an hour to go from first stage, to second float....... Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 (edited) Saw your thread with the dome light, but all mine are unplugged so I don't think that's it It's off now, will check resting voltage tonight and try it again Edited June 21, 2014 by tacomaguy1 Quote Team Flex Issues Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 21, 2014 Report Share Posted June 21, 2014 Saw your thread with the dome light, but all mine are unplugged so I don't think that's it It's off now, will check resting voltage tonight and try it again cool, your bank is larger. wait till it floats to a voltage that will allow the charger to do its thang. Around 13v .... go to 25amp, and let it eat. If you dont see float in a day or so... you have a bad cell man.....i think. You SHOULD hit the second stage, at some point, if not? Something is up, a drain or pull, or, a cell that wont take a charge.......... i know you pack some older bats.... so, im a lil worried. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Kyblack76 Posted June 21, 2014 Report Share Posted June 21, 2014 Ive been on, for what? maybe an hour. Im at 14v now. It will (if all is well) creep up to 14.4, hit it, then, chiilax to 13.5. and will maintain that forever (or untill you kill it of course) Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 (edited) Bad bat nooooo Hopefully not but we'll see It would of been recently, last time it charged perfect. Honestly a month ago though Played it last weekend and held voltage fine Edited June 21, 2014 by tacomaguy1 Quote Team Flex Issues Link to comment Share on other sites More sharing options...
tacomaguy1 Posted June 21, 2014 Author Report Share Posted June 21, 2014 Plugged it back on at 25 Watched it climb up to 25, slowly fall to around 10-11 Its at around 5 now Too hot to watch it so I came in Quote Team Flex Issues Link to comment Share on other sites More sharing options...
