Orion hcca 10.2 NEW not sounding good at high volumes
Yeeb
How do you do the big 3 how hard is it?
not that hard. took me an hour because i was drunk and i soldered everything and shrink wrap. get 0 gauge from your:
+alternator to + battery
-frame/chassis to - battery
-engine block to - battery
remember to ground your amps to your frame/chassis rather than the body. the body is paper thin and not that great of a ground.
1997 subaru legacy outback
Four 15's in a almost wall
Rockford Fosgate t2500-1bdcp
Rockford Fosgate T400-4 on tweets
Rockford Fosgate T400-4 on highs
Rockford Fosgate T400-2 on midrange
Rockford Fosgate T400-2 on midbass
Optima Yellow top batteries
270A Singer alt (working on a bracket for a second)
Lots of Second Skin
So your cousin had his wire burn up so you did the same thing?? Smh.
Your wire is to small for that amp, you need 1/0 gauge wire. The big 3 is pretty easy. Look on YouTube.
You need to ditch that Dann cap, it's not doing you good, if your voltage is right and your dropping that low, you could burn your amp up. Take the cap out and rehook your amp back you and I'm sure results might be better.
Your clipping and starving the amp.
Make sure bass boost is off
Run all 1/0g including your big 3 and get rid of your cap. Your problem will most likely be solved my friend.
8awg is for like 500w max. I use that for speaker wire..
Ask questions on here and we will all help you
  • Who's Online   1 Member, 0 Anonymous, 1542 Guests (See full list)
