soundstream15 Posted July 1, 2014 Report Share Posted July 1, 2014 Where is your amp grounded too? Link to comment Share on other sites More sharing options...
Yeeb Posted July 1, 2014 Author Report Share Posted July 1, 2014 A bolt in my back hatch. So wire upgrade big three no cap and bass knob gone go to audio shop have them tune amp and clean ground? I'll do all that. But how could it hit great for 4 days then not hit good? Link to comment Share on other sites More sharing options...
soundstream15 Posted July 1, 2014 Report Share Posted July 1, 2014 Bad ground, amp loosing power from poor wiring/install. Loose connections possibly. Make sure your shop has a dd-1 or oscope Link to comment Share on other sites More sharing options...
Yeeb Posted July 1, 2014 Author Report Share Posted July 1, 2014 Thank you sir. Do you think my basics are okay? Hifonics brutus brx1600.1d and orion hcca 10.2 with all new kenwood components. Link to comment Share on other sites More sharing options...
soundstream15 Posted July 1, 2014 Report Share Posted July 1, 2014 Yes, decent set up man. Is it a prefab box tho?? Just get better wiring and make sure it's a solid install, all clean grounds and no loose connections Link to comment Share on other sites More sharing options...
truthsayer Posted July 1, 2014 Report Share Posted July 1, 2014 How do you do the big 3 how hard is it? not that hard. took me an hour because i was drunk and i soldered everything and shrink wrap. get 0 gauge from your: +alternator to + battery -frame/chassis to - battery -engine block to - battery remember to ground your amps to your frame/chassis rather than the body. the body is paper thin and not that great of a ground. I agree with most of this except. It should be engine block to chassis. truthsayer Link to comment Share on other sites More sharing options...
Yeeb Posted July 1, 2014 Author Report Share Posted July 1, 2014 It's a box for a 12 approx 2 cu ft and I put the plate they shipped it in over the hole and sealed it. No air coming out besides the port. What is the difference between yellowtop an red top? Link to comment Share on other sites More sharing options...
Yeeb Posted July 1, 2014 Author Report Share Posted July 1, 2014 Should I use welding lead for my big three. It's super heavy duty stuff and oxogen free copper. How do I ground from engine block to chassis? Not really much info on where to ground it to the engine block. Link to comment Share on other sites More sharing options...
Yeeb Posted July 1, 2014 Author Report Share Posted July 1, 2014 One more question is it couldn't be voice coil because it is fine at 4 ohms right? I reallllly don't need it to be voice coil damage because it's not covered under warranty. Link to comment Share on other sites More sharing options...
soundstream15 Posted July 1, 2014 Report Share Posted July 1, 2014 Find a bolt on the engine block and ground it there or you can use the alternator mounting bolts. It's not your voice coil and you should or have someone build you a nice box Link to comment Share on other sites More sharing options...
