Anthony Bbgw Jefferson Posted July 7, 2014 Report Share Posted July 7, 2014 I just bought a Skar Audio IVX-12v2 400 Watt RMS 12" Subwoofer what amp should I get. Link to comment Share on other sites More sharing options...
g2shuck Posted July 7, 2014 Report Share Posted July 7, 2014 You could use a Skar LP550.1D which would give it 420rms at 2 ohms or 350rms at 4 ohms depending on what coil configuration sub you bought. 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
Hugh G. Rection Posted July 7, 2014 Report Share Posted July 7, 2014 I just bought a Skar Audio IVX-12v2 400 Watt RMS 12" Subwoofer what amp should I get. my ivx-10 is riding around on a kicker zx200.2 and its happy. termlab on the dash at 36hz was 138db, in a single cab dodge 1500. Owner of BigAss Ports Link to comment Share on other sites More sharing options...
Anthony Bbgw Jefferson Posted July 7, 2014 Author Report Share Posted July 7, 2014 You could use a Skar LP550.1D which would give it 420rms at 2 ohms or 350rms at 4 ohms depending on what coil configuration sub you bought. It is a dvc. Link to comment Share on other sites More sharing options...
g2shuck Posted July 8, 2014 Report Share Posted July 8, 2014 You could use a Skar LP550.1D which would give it 420rms at 2 ohms or 350rms at 4 ohms depending on what coil configuration sub you bought. It is a dvc. Ya if it's dual 2 wire to 4 if it's dual 4 wire to 2 2000 Toyota Camry With Sealed Off Trunk Sky High OFC Wiring DC Power 270 XP Alt AQ 2200 Sub Amp Two DC Level 4 m2 12s 80 Mil Murdetmat Gathering Parts For Wall Build. Team DC Audio 2014 Member Link to comment Share on other sites More sharing options...
