DevinG Posted July 13, 2014 Report Share Posted July 13, 2014 First off I am a long time lurker first time poster, and I am having trouble coming to a decision about what type of box to build into my trunk. At this point I have narrowed down my options to a single sundown x-15 or two sa-12 subwoofers (because of power handling, I will be buying either a soundqubed 1200.1 or a ct sounds 1400.1). However I'm not positive i can fit a 15 into my trunk, (which is H-16.5"xW-36"xD-25") it seems like too tight a fit because of the height restrictions. So my question is if there is some way to pull that off or if i should just go for the sa-12s instead. However my main reason for wanting the X is because I love the idea of murdering the lows, to me there is nothing like the feeling of a lower 20hz tone. But, if i could get close to the same effect from the sa-12s I would take that path in a heartbeat. Please advise on what might be a better course of action. Thanks in advance! DevinG Link to comment Share on other sites More sharing options...
truthsayer Posted July 13, 2014 Report Share Posted July 13, 2014 You could do the x-15. Your dimensions give you 7 cu ft, minus port and sub displacement. truthsayer Link to comment Share on other sites More sharing options...
DevinG Posted July 13, 2014 Author Report Share Posted July 13, 2014 You could do the x-15. Your dimensions give you 7 cu ft, minus port and sub displacement. Thanks for the help, I'll post a new topic asking for help with figuring out how i need to design the box. DevinG Link to comment Share on other sites More sharing options...
