My amp is mounted to the top of my box and it gets some good vibrations to my amp. Witch I am scared about. So I got to thinking, would it be OK to deaden the top of the box? Its about the only spot I have to put the amp so kinda need to make it work.
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
im gonna say no. Get some nylon or shock absorbers/rubber.
Dont think deadener works on wood well
Edited by SlamminBeats
  • Like (+1 Rep) 3
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Typical deadener will do nothing on a box. You wanna deaden it? Build it right. Brace it well.
I'm undecided about rubber washers. The amp has to be tightened down very tight, and is therefore coupled to the box via the screw or bolt you mount it with, which basically negates benefits of rubber washers. And if it's loose enough for the rubber washers to do anything, then it's bouncing around so much that it's actually much worse. I know it sounds great, but I guess I'm just skeptical they're the saving grace everyone makes them out to be. :shrug:
"Clipping" is the biggest forum boner now. It's like witchcraft... it automatically explains just about everything people don't understand.
My build log: http://www.stevemeadedesigns.com/board/topic/200295-gckless-2011-chevrolet-impala/
High resolution photos: Gilbert Kless Photography
If need be, add like 1/2" wood on top, rubber washers/spacers, then mount amp. I did this before and vibration was reduced A LOT. Cheap and well worth it.
  • Like (+1 Rep) 2
Well when it was built, thinking was that it would be good. And does have alot of bracing.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
The box don't jump, just has vibration.
Pic of the setup. Amp is mounted on top of some foam and still gets a lot of the vibration.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Just supports my previous post.
But could you move the batteries to either side of the box and then mount the amp behind the box then?
  • Who's Online   1 Member, 0 Anonymous, 1114 Guests (See full list)
