XS Power
So recently my sub's have been draining my.stock battery and from what I've been told is that it is deeply discharged and is always dying or.coming close to it. It struggles to start and was wondering what model xa battery I should get to replace it. I only have a 1200 watt RMS system 2 SA 12s and a kicker zx1000.1
Depends on the vehicle really. There is an application guide on the front page of the webstie 4xspower.com or you can download the XS Power apple or android app.
Any mid size battery that you can get under the hood should work fine for you. Really just depends on what fits under the hood.
A couple of other things I would also check is if the alternator is working properly and does the battery you have work fine if you charge it up with a battery charger. If you are playing your system at high levels 90% of the time you are driving, then the alternator never has time to charge the battery back up. Maybe try topping it off with a charger and see if that helps.
  • Who's Online   1 Member, 0 Anonymous, 1757 Guests (See full list)
