So I've got my DD1 coming and just have a couple questions.
Syphlyn
Hey guys my DD1 is on it's way and should be here by Saturday and I just have a couple questions. I was looking through this guide:
http://www.stevemeadedesigns.com/board/topic/96978-test-tones-and-tuning-tutorial-all-new-links-again/
1) When figuring out my max HU volume do you use a lower amplitude tone like 1000hz -5db and then the 40hz -5db. Or is it best to use the 0db tones?
2) If I set my HU using -5db tones (40hz and 1000hz) do I have to use -5db tones to set the amps properly? If it's best to use 0db for the HU can I use the -5b tones for the sub amp and highs amp?
3) When doing the HU can I just connect the RCAs from the head units preouts into the DD1 or is it best to go through the amp as it's described in the manual? Will both achieve the same thing?
- I mean the RCAs that would plug into my amp just plug into the DD1.
Thanks guys just wanna make sure I'm doing it right!!!
Syphlyns 2000 F150 4.6L V8
H/U: Kendwood KDC-X898
Speakers: 4 x Alpine SPR-68 Speakers
4 Channel Amp: Alpine PDX-F4
Sub: Sundown Zv4 12
Sub Amp: Sundown SAZ-2000D
Box: 2.75 Cu Ft @ 31Hz
Alternator: Mechman 250A elite series
Wiring: All KnuKoncepz 0 gauge OFC + KnuKonceptz Krystal RCAs
1) use 0 db tone
2) on the amps you can use 0,-5, or -10
Just depends on amp and speaker combo and how hard you want to push it
3) can't help you their as I've only done it through the amp
If I do it from the amp should I do the 40hz tone on my sub amp and the 1k tone on my mids/highs amp? Will that be a good way or do I do both on the mids/highs amp?
Thanks
Sub: Sundown Zv4 12
Follow the directions...
done
Beat me to it. The instructions are step by step, and answer every one of your questions. You can download them from http://www.damoreengineering.com.
2015 Toyota Tacoma Build Thread
2007 Mazda 3; 5000K HID's, Kenwood Excelon KDC-X997, Infinity Reference 6.5 comps in front and coaxials in the rear doors, JL 320.4 four channel, Rab Designs built ported enclosure with an SA12, Kenwood monoblock, Redline Leater shift boot/e-brake boot/center console cover, JBR short shifter/shifter bushings/rear motor mount.
Build Thread
1996 Mazda Miata: Kenwood Excelon HU, Alpine speaker in the doors, Clearwater (miata specific) headrest speakers.
1994 Mazda Protege: Kenwood Excelon HU, Infinity Reference 2 ways all around, 2x RF Punch 10's in ported boxes.
done
done
Okay I was misunderstanding those points.
But here's one I can seem to understand from the manual. When setting my head unit can I just plug one of the RCAs from my HU into the SMD DD1 directly? Does it matter which one? Ones red and ones white.
Sub: Sundown Zv4 12
Yes you can just use one rca from the headunit to find where the deck distorts. In my experience the right one usually works but may not always be the case.
I have a PAC-LC1 hooked up (well going to). So I'll have the RCAs from my HU plugged into that and then another set of RCAs coming out of the PAC-LC1 can I attach the DD1 to those as I want to incorporate the PAC-LC1 while tuning. My plan is to have it cranked so I can't go above the way I set it, I just want a way to lower the volume if needed.
Sub: Sundown Zv4 12
