Think I Broke Something (Ford POSI Rear End)
Already emailed my mechanic, but lets get some feed back here. Please don't spam up this thread with assumptions unless you know a little something about the topic. Thanks.
Symptoms:
-Lately, ive noticed that the whine from the rear has become louder. Its easy to hear with on seats or deadener in that area. Well, today it was really loud. Start to hear it at 40mph and it gets louder. At 80-85mph it is crazy/obnoxiously loud.
-The sound can be manipulated by throttle position (changing the load on the rear gears), and it almost disappears when the clutch is depressed at speed.
-Also, the noise gets worse in a left turn and almost disappears in a right turn. Im talking about long lazy curves at speed on the freeway.
-These cars are known for clunking noises from the rear suspension, but the occurrence of these sounds has increased.
-This is a weird one. This morning when I left my parking spot, I released the ebrake and depressed the clutch and the car didn't move. It usually begins to roll out on its own. Let out the clutch a little and there was a clunk and the car started to roll. Felt like a sticky e- brake,
but I believe it was the POSI somehow stuck.
This rear end has spider gears and carbon-fiber clutches. I think one or both of those is failing on one side. Maybe the springs are going bad causing the clutch system to function incorrectly? Any opinions?
SMD Super Seller
My Feedback Thread
Sounds like a pinion gear issue.. May be a loose pinion nut and or pinion bearing or gears.
Pinion noise comes on loads and will go away when not on acceleration
Edit: sorry didnt read the last part. You may have a second issue with the posi track. Unless the Pinion gear is that loose its binding up. Bearing can bind up as well
Thats cool. Im way too old to be upset by shit like that. Your name is winston. Your own parents hated you even before you were born.
My penis is bigger than your penis
I'm far from loud and my roof/headliner flaps around like Adam's ass on a windy day. I think it depends more on the structure of the vehicle.
tuned in for results. The 9.75 in my dad's 03 SuperCrew is LSD unit, also has a VERY noticeable whine anywhere above 35mph.
Whats your take on my third bullet point, the increase in noise turning left, and no noise at all turning right.
Pinion gear/bearing sounds like a good place to start.
SMD Super Seller
My Feedback Thread
Possible axle bearing?
Edit: when turning it loads the side and can cause a noise.
I thought about that.
I'm still leaning towards the pinion gear, and the different loads that are seen. The way everything turns in there, it could load different in different turns.
Thanks for the help, man. Ill have pinion and axle bearings all checked out.
SMD Super Seller
My Feedback Thread
Difference in long corners would show a different speed (rate of rotation) between the rear wheels.
I'm going with the posi being the issue.
Would explain difference in toruqe load, but not the "parked lock up". Unless the care was not straight parked.
Edit- the pinion and ring gear back lash would explain a lot of the issues, the corner thingy is odd.
Axle bearings can cause that, recently on my fathers explorer the axle bearing was making noise and finally let loose and broke while driving. Now is it a constant noise or is it one that appears when the wheel is in the proccess of making a revolution and makes the noise in a certain spot while the wheel is making that revolution, if you get what I mean?
2000 Ford Focus ZX3
Mods:
Raceland Coilovers
Borla Exhaust
Aftermarket Header
System:
Sony CDX-GT66UPW
Pioneer 6x8's
System Upgrades :
Pioneer MVH-X560BT
2 sets of Rockford Fosgate P1683's
Fi Audio Q 18" D2 ( Currently Own)
DD M1C ( Currently Own)
All SHCA Wires and stuff...
XS Power 4800 ( Stock Replacement)
High Ouput alternator (undecided which company or Amperage.)
A bad bearing could cause the turn difference, too, by not allowing the axle to spin freely, and preventing the posi from functioning right.
That stuck thing was weird, bro. Thats the real head scratcher. But thena again, a bad bearing could kind of stick until forced to move.
Fuck me, ill just replace it all.
Constant.
SMD Super Seller
My Feedback Thread
If its a bearing (pinion or carrier) .. I would just install a bearing Kit
  • Who's Online   2 Members, 0 Anonymous, 1548 Guests (See full list)
