DC Sound Lab
sub terminal reading higher ohm than at tinsels landing
was checking the ohm at the 8guage terminal opening and getting funning readings, but At the tinsels and the connection its reading correct, i want to know why is that? this is the second time ive came across this first time i played with the upper terminal connection that solders to the tinsels and it began to read correctly at the terminal this time its not.
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
The term ohm is referring to its resistance. Higher means more resistance. So at the spider pack or wherever your meauring on the sub it's getting slightly less resistance. Once it goes through push terminals, wire, and a terminal cup... Even if each one of those things only adds .05 resistance it will Add up from (example) 1ohm to 1.15ohm, in my example of course.
I'd check to insure your connections are as tight and corrosion free as possible. Loose connections and corrosion will add resistance every time.
My old YouTube channel : http://www.youtube.com/user/SwordLords1234?feature=mhee
My old build log : http://www.stevemeadedesigns.com/board/topic/161872-96-accord-b2-sundown-sky-high-dc-power-re-re-build-for-heatwave/page-37
My New Build - http://www.stevemeadedesigns.com/board/topic/207041-2016-mazda-6-sql-build/
2016 Mazda 6 Touring
JL Fix 86 - OEM signal correction
B2 prototype DSP 6to8
B2 Ref63 - 3 way active set
2 B2 Class H quattro's
1 B2 Zero.5R @.5
2 B2 HNv3 12 d2
B2 SLIP40 - Lithium in the trunk
Northstar Group 35 under the hood
100ft 2/0 welding cable
30ft 4ga welding cable
20ft 8ga welding cable
All stinger OFC speaker wire
Soundrive custom RCA's
Tons of attention to detail.... Can it be perfect?
If you have a D2 subwoofer and it reads 2 ohms at the leads on top of the spider but the terminal itself reads 4 ohms then the solder connection inside the terminal needs to be re heated with a soldering iron. Test it again after the terminal has cooled off. Should be good to go
DC AUDIO
Phone Number
1(855)SPL-DBZZ
Built by Competitors, for Competitors.
