Please help with a 2000 Civic alarm
I am trying to install an AutoPage RF-225A alarm in a 2000 Honda Civic,and having lot's of trouble with it.I can not figure out the unlock/lock doors,horn.sensor,and almost everything else.I have spent 3 days on it,googling it,and am lost.If someone knows what wire's,location of wire's,and how to install this thing,it'd make one guy really happy.
Constant 12V+ White Ignition Switch Harness
Starter Black/White
Ignition Switch Harness or White 6 Pin Plug behind Fuse Panel Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Yellow Ignition Switch Harness
Accessory Yellow (+) Ignition Switch Harness
Tach Blue Coil
Neutral Safety Wire Black/Blue (-) Brake Switch Green/White Brake Switch
Trunk Pin Blue/Black (-) Driver's Kick or Alarm Connector right of Column
Parking Lights Red/Black (+) Keyless Entry Module or above Fuse Panel
Head Lamp Red/White left. Red/Blue right at Steering Column
Door Trigger Light Green/Red (-) Alarm Connector right of Steering Connector is Green
Door Lock Green/White (-) Above Fuse Panel or Keyless Module or behind Radio Green Connector
Door Unlock Green/Orange (-)
Driver's Lock White/Red Driver's Kick Panel
Driver's Unlock Blue/Red Driver's Kick Panel
Passenger Unlock Yellow/Red Keyless Entry Module
Horn Wire Gray (-) Steering Column or Green Connector behind Radio
Windows Up LF=Red/Blue, RF=Blue/Yellow, LR=Green/Yellow, RR=Yellow
Windows Down LF=Red/Yellow, RF=Blue/Orange, LR=Green, RR=Yellow/Green
  • 5 months later...
