Is the issue inside the housings, or on the outside?
LMFAO so true
:blush:
Mitsubishi 3000GT (Old Build)
Headunit: Pioneer 80PRS
2005 Chevy Colorado Ext Cab
My Official Feedback Thread
Most headlight restoration kits are under $20...they have everything you need.
Avalanche
Alpine Type S comps
Alpine Type S 10''
Alpine MPR-F300
Alpine MRX-M50
Mechamn 270
XS Power d3400s
Home Depot has a polishing kit for drill with compounds
Wet sand then buff. Kit was like 15.00
Pioneer P99RS
Ampere 3800
2-Ampere 125/4
4-6.5 inch Hertz HSK XL Mids
2-5.25 Satori Mids
2-Hertz Silk tweeters
DC Audio Level 5/12
Skyhigh Wire
Mechman 320
XS Power D3100
I had luck with Mother's Plastic Polish. Had to be applied at least once a month but it did a decent job. Depending on the vehicle I would just buy new. Tried to restore mine once and turned out like shit. The inside of the lenses are very very sensitive to abrasion. You can find them pretty cheap some times on parts geek or rockauto.
2013 F150 Crew Cab
Old Build Log
Feedback
2013 F150
  • 1 month later...
I just used bakingsoda and peroxide toothpaste on mine. Follow up with some head light kit. The kit didn't help any more than the toothpaste. I use a magic eraser when I used the tooth paste.
Next step is to try to take them apart and wet sand/clearcoat
Any one got tips on how to get these apart and what to use to glue the back with?
The bug spray with high deet works. I did mine with 220grit sandpaper on a d.a sander. Then used a sanding block with 2000 grit with soapy water. Then I clear coated them with actual automotive clear, not cheap junk. Even removed the level plastic tabs that are molded to them and cant see they were ever there. They look damn good like factory.
Duck, youd have to bake them open in a oven. Then use clear waterproof sealant. I forgot his name, but he did a retrofit in his altima, red and black? Hed know more.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
