Hey everyone. I'm in the process of getting a sundown audio saz3500 to push my 2 X10 in a kerfed ported box tuned to 33 Hz. Have two xs power d3400, high output alternator, big three (1/0). Even though there's really no such thing, is this too much power for these subs. They would be in a one ohm load. I've seen some people only running a 2500 on a single z18! Just like to get some feedback. .. Thanks in advance! Also, is two runs of 1/0 necessary for this setup?
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
With quality 1/0 or 2/0, you'll only likely need one run if it's OFC. You didn't mention how big of an alt you're going with , but if you can only supply 200-250A of current, a single run of quality OFC should be sufficient.
its a custom made alternator from Mike over at Singer. 210 Max/180 amp, 130 at idle...a far difference from my 80 amp max OEM alt. ive been using Knukonkepts 1/0 OFC and ive been happy so far...
two runs of 1/0 pos and neg from front batt to back? then 2 runs of 1/0 pos and neg to amp?
Singer 220 amp alt
will I need two batts in the back? I didn't plan for that, but im not gonna be that guy who fries sh*t up.
Singer 220 amp alt
Your not doing 2 runs positive and negative to a 3500 unless you get toolmaker dual input terminals ;-)
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
Yeah. ..I know some peeps who could help me out with getting custom terminal inputs. .. But if i don't Need them, I know the 3500 only comes with one positive and one negative. I'll get everything together with a dd1. ..I guess just product handling and voltage drop ate my concerns.
Singer 220 amp alt
  • Who's Online   0 Members, 0 Anonymous, 1026 Guests (See full list)
