Myispheres Posted August 23, 2014 Report Share Posted August 23, 2014 need help please I have a 1999 blazer v6 been running fine drove it home less then 1/4 mile from work next day would not start it rolls over has spark fuel pump sounds like its working i did run out of gas 1 time it did take along time to get to start . i did try to start it with starter fuild still nothing any help please and thank Link to comment Share on other sites More sharing options...
Hotdog Posted August 23, 2014 Report Share Posted August 23, 2014 Try disconnecting your battery then doing this. Then This (NEW) 2004 F-150 Build Log -->http://www.stevemeadedesigns.com/board/topic/192208-hotdogs-f-150-build-log/ 2003 Mercury Mountaineer Build Log --> http://www.stevemeadedesigns.com/board/topic/114380-hotdogs-2003-mountaineer-build-log-20-removed/page__gopid__1602379#entry1602379 2008 Equinox Build Log --> http://www.stevemead...g/#entry1475764 Link to comment Share on other sites More sharing options...
Myispheres Posted August 23, 2014 Author Report Share Posted August 23, 2014 i did that unhooked the neg on the battery over night Link to comment Share on other sites More sharing options...
Miguels Posted August 23, 2014 Report Share Posted August 23, 2014 how long has it been since you changed the plugs my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
jdshott Posted August 23, 2014 Report Share Posted August 23, 2014 Spray it with 2 short burst of ether (starting fluid) it should start and stay running . If you have codes then find out what they are . a no start issue can be anything. DO NOT KEEP USING starting fluid if it works you can cause more damage doing so . No 1 But me paid for this stuff and NO FREEBIES so no brand names (No Free Advertisement ) A SQ head unit 6 5.25 2 X 6x9s 7804 P400.4 4001D 1 34s (Maybe time to change brand) 4 X 15" s !/0 @ 2/0 OFC Wiring :morepower1: :morepower1: ill say it like i always say it. F##K the DD-1. I don't care if you or anyone buys one. (well i do, but that isn't my point) Get an O-scope in the very minimum and learn how to use it or you are just guessing your settings like every other noob. once you master the O-scope then step up to a DD-1 or even better a DD-1 Plus. Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted August 23, 2014 Report Share Posted August 23, 2014 Just because the fuel pump is making noise it doesn't mean it's working. check your fuel pressure. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
Miguels Posted August 23, 2014 Report Share Posted August 23, 2014 also check for a clogged fuel filter my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/ Link to comment Share on other sites More sharing options...
Myispheres Posted August 23, 2014 Author Report Share Posted August 23, 2014 I tried that it wont start with starting fuild wont start that way the blazer was running fine then I drove it home no service engine was on went to start it the next day rolls over just wont start and run Link to comment Share on other sites More sharing options...
Broke_Audio_Addict Posted August 23, 2014 Report Share Posted August 23, 2014 Check the fuel pressure. That being said a lot of people's definition of "music" is a clipped 30 hz sine wave with some 80 IQ knuckle head grunting about committing crimes and his genitals. Link to comment Share on other sites More sharing options...
