XS Power
Is HF 14 15 right charger for D3400 12 volt?
Probably looking dumb here. .. But i have to make sure!
2007 Chevy Aveo Ls sedan
2 Sundown Xv2 on scv4k @ .5 ohm
2 pair RE XXX 6.5 components on sax200.4 @ 2 ohm
Big Three, Three runs 1/0 power from front to back, 1 ground front to back
Two runs ground from rear bank to chassis
XS power d3100 upfront, 3 Odyssey 2150s in bank
Singer 220 amp alt
Bump to top please!
Singer 220 amp alt
You need the 1215 for 12 volt batteries charges to 14.3ish then floats. The 1415 is for 14v batteries charges to 16+v
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
Well shit. ..I accidentally ordered the wrong one. I put my brand new D3400 on it for about 3 to 4 hours. .. Before realizing it was most likely the wrong one. Please don't tell me my batt is garbage now. Packing charger up to send back today. And I'm gonna test the D3400. .. wish me luck.
Singer 220 amp alt
Why wouldn't you ask before you order and not after you already have it on your battery?
I don't understand how you could even order the wrong one, if the specs don't make sense to you then how did you set up your whole system?
2007 Chevy Tahoe (SOLD)
2 ~ DC Audio 5.0K @0.67
3 ~ DC Audio 5.0K @1.0
1 ~ XS Power D4800
1 ~ XS Power D3400
8 ~ XS Power XP3000
320+ Sq. Ft. Sound Deadener
Pioneer AVH-X5500BHS
Is the 3400 swollen?
Highly likely that there is some serious damage to your battery. The 14v chargers go into absorption mode at around 16.8v IIRC.
If the battery tests good under load(testing internal resistance), put it under an extended 25a load and post back how long it lasts before dropping below 10.5v. That is a measure of the battery's capacity. I'm willing to bet that even if the load test is good, it will fall flat on it's face on this test.
Edit: Now that I think about it, overcharging isn't warrantied by XS. You might be SOL
You could always pop off the sticker, top cover, then little rubber nipples covering each cell and add some distilled water. Around 30ml per to start off. It would help with the capacity problem, but I doubt it would bring it back to new
Edited by SnowDrifter
testing at 13.3 My wife bought it for me...should've double checked...the confusion came from 12 volt vs. 14 volt running...time will tell...3400 is NOT swollen...in the very worst scenario...its just one battery...
Singer 220 amp alt
Resting voltage can/will be good even is the battery is bad. Especially if it's boiled off the electrolyte
Uhh.... Try this: Put it in your car, only the d3400. Does it start? Ok. With the ignition on but car not running, turn on the headlights and time how long they stay on before battery voltage dips to 10.5v.
  • Who's Online   0 Members, 0 Anonymous, 805 Guests (See full list)
